biggest rotors that will fit under skinny front drag tires
As stated in my title I need to know what is the biggest brake rotors or brake system I can run on my 99' Z28,it will be mostly for street use and occasionally see the track but I want the biggest rotors I can get that will allow me to still run skinnies up front. Is it possible to run a 6piston setup upfront without issue?
Glad to know I can fit those rotors on the front. Now do you think it would fit with a 6pistonlittle caliper? Im just trying to get the best clamping power I can without spending thousands for the huge brake kits. Just concerned about the rims/tires not fitting with a 6 piston caliper.
Guys that are interested and need help, if there is a special brake package you are interested in, check with the brake company and ask for a caliper profile sheet which most have on file. Send it over to me and I'll let you guys know what I can make work and what I can't do with our Bogart wheels. Without this information, its all a guessing game. I thought I had a post on here before but not sure what happened to it.
