02 TA Koni SA`s with Spohn Delrin LCA`s ... Squeak?
So I have a nasty squeak on the driver side rear, the squeak occurs when i hit bumps or push down on the back of the car. The shocks seem to be tight though and do not seem blown at all. Very Very stiff when pressing the back up and down. That being said its driving me nuts and I was wondering what everyone though it may be?
Did you grease the LCA's properly? (with a grease gun?)
What other suspension mods do you have? Did you move your exhaust around at all when installing mods? (loose exhaust can sound and feel like a suspension squeek).
I have a similarly stiff suspension setup. Are you absolutely positive that the squeak isn't coming from inside the car?
I had a ridiculously annoying squeak and couldn't figure it out for the longest time. It turned out to be the rear seat making noise where it clicks in the upright position (metal to metal) because of the stiff suspension. Car never made that noise with the sloppy stock suspension.
LS1Tech Premium Sponsor
