adjustable panhard bar????
Old Mar 13, 2004 | 02:27 PM
MaverickSS's Avatar
Arrow adjustable panhard bar????
ok guys i havea BMR adjustable panhard bar, and cant figure how close the outside ends should be, if you have a pic of one in a car that would be good, but i did tightne mine and it threw the toe alignment and thrust angle off in the rear so im stumped, PLEASE HELP! pics please!
Old Mar 13, 2004 | 04:14 PM
DARK AGE 53's Avatar
Did you follow these instructions? http://www.bmrfabrication.com/instructions/phr003.htm
Al
Old Mar 13, 2004 | 04:19 PM
Old Mar 13, 2004 | 10:50 PM
mitchntx's Avatar
Those bars scare the **** out of me ...
Old Mar 14, 2004 | 03:17 PM
Svingos129's Avatar
I just aligned mine with the factory bar and made sure the threads were equal on either side of the nuts...no problems yet with mine.
Old Mar 14, 2004 | 05:57 PM
Fulton 1's Avatar
No kidding. Everytime I see a pic of the new ones with the adjustment in the center it makes me cringe.
Old Mar 14, 2004 | 06:41 PM
mitchntx's Avatar
Why would anyone connect 2 LCAs together with all thread and call it "extreme" is either a crazy or marketing genious.
Old Mar 14, 2004 | 07:44 PM
Did you mean two panhard rods?
Old Mar 14, 2004 | 09:05 PM
mitchntx's Avatar
No ... either half of that design is about the length of an LCA.
Connect them with all thread and voila ... instant APHB
Old Mar 16, 2004 | 08:52 AM
mitchntx's Avatar
connection points double ... one on each end and 2 side by side in the middle.
As far as ease of centering ... you should only have to do it once.
Would you even consider connecting 2 LCAs with a piece of all thread and using it in a loaded environment?
If you needed a shorter (or longer) pushrod in the motor, would you grind them down or lengthen them?
Same difference and probably less loading on the push rod ... around 250lbs of constant spring pressure vs 15000lbs (1/2 the car's weight at just under 1G) of loading, alternating between compression and stretch.
Old Mar 16, 2004 | 09:34 AM
2w0s060's Avatar
So which PHB would you recommend? I understand somewhat what you are saying, but do you suggest to use?
Old Mar 16, 2004 | 10:49 AM
Scalpel's Avatar
Get one from Trackbird, they're aluminum and use the same awesome rod ends that LG uses, the QA1 XM series
Old Mar 16, 2004 | 11:37 AM
mitchntx's Avatar
This is an interesting conversation ...
http://mtfba.org/rrforum/index.php?act=ST&f=3&t=671&
draw your own conclusions ....
Old Mar 16, 2004 | 01:42 PM
Fulton 1's Avatar
Originally Posted by MarineSS
I have that same panhard for ease of centering the rear. Previous to this
I had the Hotchkis adjustable and at that time, I knew of no other way to
center the rear. Why is it scary
Not only do you have the reduction in cross-sectional area and the additional stress-risers associated with the adjusment, but you have it located at a very critical point - that's the thing that bothers me the most about this design. If you place the bar in compression (e.g. a righthand turn) the maximum bending moment in a simply supported slender column (assume its experiencing both axial loading and bending loads) will be at the center of the length. Exactly where the damn adjusting feature is placed with the BMR design.
The bar may well be "strong" enough to handle the loads placed on it, but IMO that just means that weight could have been saved with a more elegant design.
Old Mar 16, 2004 | 02:12 PM
2w0s060's Avatar
That is very interesting...
So what if you went with a design like Spohn where the adjustment in the bar is towards one end and not at the middle, but still having tubular ends with poly bushings? Is there a difference in this design? Just a thought...
http://www.spohn.net/product.cfm?productid=1297
Old Mar 16, 2004 | 06:04 PM
mitchntx's Avatar
I'm all for innovative ideas and trying new things.
But sometimes, simple is the best.
I've found what I like and it works very well for me. I'm tired of investing my hard earned money on an experiment.
Old Mar 16, 2004 | 10:09 PM
trackbird's Avatar
I'm with Mitch, and I was thinking the same thing when I saw that picture. Please tell me that BMR POS is not under a $100,000 Berger car.
