inner tire wear on lowered car
my car is lowered in the front and has serious tire wear on the inside. still have the tires from the previous owner installed. i ordered a new set of tires and i want to avoid from this kind of tire wear. would a simple alignment solve this issue or should i start looking into a caster camber plate? i have 2 different tire sizes so i obviously can't rotate them and the car does pull towards the right. i'm pretty sure an alignment would help this just thought i'd get some input from anyone having knowledge or the same experiences. thanks.
^^^agreed a good alignment will fix the problem but make sure you put on your new tires before you get it done and then youll be good to go.
did you change any other front suspension by chance? my ws6 was like that (i needed tires reguardless) but after the complete upper and lower adjustable a arms and sway i was a little off .... alignment = problem and camber fixed
Save the manuals!
My stock car has done this from the factory, but wear is a relative thing... One person's "problem" is another person's "no-problem." These cars are also bound by the directional tires. Unless you purchase non-directional tires or re-mount them during their lives, (Both come with disadvantages.) you'll always have some uneven wear.
Can you post pictures of the current tires or post some measurements taken with a proper tread gauge?
