Full suspension on 02 SS
I have a 2002 camaro ss and i am looking to do suspension work on it but im not sure what what to get or where to get it? or what to start with?
Any help or advice will be greatly appreciated!
Thanks
Thanks
What do you plan to do with the car? Street/strip/auto-x/road course track day?
We did a build awhile back which may interest you.
http://www.umiperformance.com/catalo..._page=02camaro
Let us know your plans.
ramey
LS1Tech Premium Sponsor
We offer plenty of street/strip options from your typical upgrades to your more all-out race parts that might be too aggressive for you since you daily drive the car. However, many people still run some of these parts without any issue because they are willing to tolerate some of the harshness and noises that can be introduced by changing out some rubber parts for polyurethane or rod ends.
If your suspension is stock for now, this is how I would start you to get the most.
The first three items are going to be must haves, IMO. The lower control arms and relocations will help the car prevent wheelhop and the aggressive angle for the control arms will help the tire "bite" and get you out of the hole. The torque arm would be the logical next step to get the car hooking up and get you down the track.
Depending on how wild you want to get with it, I can suggest shock options, weight reduction, and tubular front pieces but these are the good starting points for the LS1 F-body and are what I did on the three I had to get me into the 11s and 10s with quick 60fts.
- Subframe connectors
- Lower Control Arms
- Relocation brackets
- Torque arm
- TA relocation crossmember
I'm searching for something here to sound brilliant but it would appear Kevin nailed it.
The only thing I can come up with is the decision between long and short torque arm. The transmission mount (actually relocated to beside-the-transmission) is good for street and mild strip while the tunnel brace mount tends to be for strip with occasional street. You can ride a little bit quieter with the trans mount T/A and still have decent forward traction. The tunnel mount introduces some cabin noise since it's "workin'" right beside you.
ramey
ramey
Cool build Ramey... i can only wish for all that stuff... but some day...
to the OP, What shock/spring package you think you'll go with? I think i'm set on bilsteins and strano's springs.. though i hear that Monroe Sensatracs have a life time warranty, are pretty cheap and ride like my grandmothers old *** caddy... ohh and best of all ... MADE IN AMERICA....
