Anybody DD a Tunnel Mounted TQ Arm?
Well guys if you do DD a Tunnel Mounted TQ Arm have you noticed a decrease in traction under heavy braking or decreased handling? I accidentally ordered the wrong setup. I had no idea that the short one was more leaned towards drag racing. Eventhough i have never been to a road course i would like to try it out sometime. Is this TQarm style gonna ruin it for me? Most times i go to a track its a drag strip so it will help there but i DD this car and would say its a 70% - 30% street to drag duty. And i am a very "spirited" street driver in DD mode and want the car to handle very well. Did i mess up guys?
Send it back and get what you want. Lots who go back to driving on the street go back to a full length arm because the short arms can be extremely harsh on the street. You'll likely get a million opinions but that's mine
I'd go with the stock length torque arm with a torque arm relocation crossmember. The main thing that causes a difference in handling is the torque arm's ability to twist when the rear end articulates. With a tunnel mount torque arm, the front mount does not rotate, whereas the stock length is round and fits into a round bushing. Imagine taking a very hard sharp corner, and the suspension articulating, the torque arm will cause a bind with the tunnel mount.
The adverse effect on braking is due to instant center, which I do not fully understand yet.
I do not own a short arm, and likely never will. But a lot of the guys I talk to say the noise and vibes being transmitted are not fun at all on the street. These are guys that go the track regular and have had dumped exhausts etc. So I happily accept their unbiased opinion. Basically if you don't NEED the short arm, don't get it.
LS1Tech Premium Sponsor
Depending on which one you went with, shorter torque arms will all increase interior noise to some degree - even a relocated stock arm will increase noise because you're eliminating a sound isolating bushing. That is the only difference in actual ride you'll find while your run a short torque arm on the street.
I daily drove with the XTA001 on my SS for about 5 years and didn't really bother me. Braking performance was indeed hindered by the shorter arm, that's just physics, but it wasn't a dangerous problem that prevented me from braking safely in an emergency situation. However, in some scenarios, you could come across a problem with the shorter arm when you try to autoX or road race where you'll be hard on the brakes more frequently and notice the difference.
- Kevin
- Kevin
I did the same thing and accidentally got the short arm without realizing the impacts on doing autox or road courses. I will have to disagree withe the BMR rep and say that hard braking caused a very dangerous situation for me on multiple occasions on the track. It caused the rear to wheel hop under hard braking before going into a turn. I nearly went off the track sideways a couple of times. I went back to thet track with a normal length arm and had no problems. Do some research on the mounting points for these too. You'll find for those guys that have run them long term that they will destroy the mounting points and will eventually require reinforcement or at the very least some repair welding. The tunnel brace mounting points were never designed to bear the load of a torque arm.
well the good news is i called to talk about this and the order had not shipped already so i was able to switch my order to the Torque Arm Relocation Bracket.
i know i do want to eventually switch my car to a drag only setup. but right now while i am DD'ing the car i think its best not to have a short torque arm cuz i do "DRIVE" this car on a regular basis hard around turns and am tough on the brakes. so im glad i was able to change my order. thanks UMI for the great service and i apologise for all the hassel. and thanks everyone for the insight.
I had a short tunnel mount TA with my Midwest 9" rear and ditched it for the long arm. For starters, there is a lot more noise and vibrations felt in the seat with the short arm plus it broke one of the tack welded mounts of the bottom of the floor and I dont even race.
Went with the long arm recently and the noise and vibes are greatly reduced plus the design is simply more robust since it attaches to the tranny mount instead of the floor.
for you guys running the tunnel mount TA with DSSL, does it hit the exhaust? my buddy with lt's and ory said his spohn tunnel mount TA with DSSL hits his exhaust? i find that extremely annoying for a part im about to pay $400 for...
