Remove rear spring rubber on 4th gen
Old 04-26-2012 | 01:24 PM
PACKETFOCUS's Avatar
Default Remove rear spring rubber on 4th gen
I'd like to run the stock 4th gen springs on my street/strip car but would like to lower it an inch. Are the rubber pads the springs sit on mandatory?
I haven't looked under the car in a while but was just thinking about this....
Old 04-26-2012 | 01:32 PM
02TransAm/Batmobile's Avatar
No it's not mandatory. People remove these isolators to lower their vehicle, it's called the "heater hose mod". Use the search bar using those words and you should find a ton of info on it.
Old 04-26-2012 | 01:51 PM
Awesome thanks man.
That should have my car sitting right!
99zee's Avatar
^^X2^^ Pull the rubber out and cover the top coil with some heater hose.
Old 04-26-2012 | 01:55 PM
Word. Thanks guys!
Heading down to the shop tonight to try it out.
Old 04-26-2012 | 02:02 PM
z28bryan's Avatar
But that's only about 1/2 an inch right?
Old 04-26-2012 | 02:07 PM
Yeah I heard as much as 3/4" drop.
https://ls1tech.com/forums/suspensio...l#post16243881
I got AFCO dbl adj all the way around, with coil over shocks on the front. Rear have AFCOs in stock location with a Relocation spacer made so the shocks are turned and the **** isnt close to the anti-roll anymore.
Old 04-26-2012 | 02:38 PM
thegodfather899's Avatar
yea make sure you wrap at least a coil in heater hose so you aren't running metal on metal for the rear springs
Old 04-26-2012 | 04:44 PM
99zee's Avatar
It won't do a full inch, but it may work for him. It's an easy swap so it's worth a try.
Old 04-27-2012 | 11:09 PM
Thule's Avatar
mine has vogtland 1.2" springs+ hose modd
Quick Reply: Remove rear spring rubber on 4th gen
