no traction help
Old May 7, 2012 | 03:45 PM
redtransam95's Avatar
Default no traction help
anything past a blip of the throddle im roasting tires need some grip here. have bmr panhard bar bmr torque arm bar bmr rear control arms le2 cammed 355 LT1 lt headers on and on and on do i just need sticker tires im running 275/45/18 goodyear f1 runflat tires on rear
also 3600 stall
Old May 7, 2012 | 05:15 PM
UMI Sales's Avatar
Relocation brackets, tunnel mounted torque arm on top hole with 2.5 deg driveline angle, light rebound front shocks...
Ramey
Old May 7, 2012 | 07:17 PM
done all that already exept front shocks
Old May 7, 2012 | 07:44 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
you never stated what rearend gear ratio !
Old May 7, 2012 | 11:02 PM
SS SLP2's Avatar
I thank the 18 s alone MAY cause some problems by them self as they have short side wall and the runflats alone may cause problems and when you add the two togather then you have two strikes against you
just my .02s Johnny
Old May 9, 2012 | 11:11 AM
1lejohn's Avatar
Slicks. LOL, Really drag Radials or a better (softer tire) will help. The shocks will help at the strip but not much on the street. Mount the battery in the rear take weight off the frt etc. Frame connectors and a bar will tie the car chassis together and make it work more efficent.
1st gear in my car is still a waste with all the above mods. I walk it out of the hole and have it shift into second then nail it. Thats on the street. At the track on slicks its much better.
Old May 9, 2012 | 12:53 PM
roy's Avatar
roy
Bingo!!!!
