Subframe connectors causing vibrations?
When my subframes were welded. Many years ago. The tires weren't supported. When I took it off the lift. The car immediately felt funny. I've driven it every since. However I'm notnsure when the intolerable high speed vibrations started. I've changed tires. And rims and both several times. It's still there. I added lca and then went to double polystyrene. Still there. I had tokicos then went to a Strabo koni set up. I picked up .3 in the quarter. But still there. Ive checked the drive shaft and changed the tranny mount. Still there. I have a dammed m6. I'm wondering if the frame somehow is jacked and not allowing the wheels to sit evenly which causes my low trap speed and serious vibration. The freakin car feels like its going to shake apart at high speeds. I think i could actually spped up if i didnt have the vibration.
