Poor Straight Line Tracking
I find myself twitching the steering wheel back and forth constantly when driving a straight line on the highway. The TA has 235k miles on it. I have a new rack with all new tie rod ends, new strano springs with billsteins and new double adjustable panhard bar.
I need some ideas on what other parts could be causing this. Front control arm bushings are still the originals.
TIA
TIA
TIA
TIA
Rubber has an expiration date. I feel that any factory rubber bushing should be replaced on F-bodies at this point. It's also a good time to upgrade. ;-) haha
- Kevin
- Kevin
The lower A-arms probably have the most important bushings that need to be replaced. I say this because they probably see the most action/stress over the years. One of those bushings operates its entire life in bind, which is why we only offer our A-arms with a rod-end/poly combo. When these go out, it can impact tire wear, handling, and alignment. The uppers don't go out like the lowers will, but they still need to be replaced too. From there, I would replace the rear lower control arm bushings, rear panhard bar bushings, the torque arm bushing, always upper shock mounts - especially when you're looking to change shocks.
A good rule of thumb is to take a look at your bumpstops...if those have started to fail and crumble, there is a good chance other rubber parts on the car that are not too far off.
- Kevin
- Kevin
- Kevin
- Kevin
I swapped the bump stops (they were chewed to hell) when I did the shocks/springs as well as the rear control arms, panhard bar, front shock mounts. Don't recall it wondering as much as it does now until after I replaced the rack and outter tie rod ends. Wondering if I didn't torque them down enough .... hmmm ... not to say I don't need to do the A-arms and any other parts that you mentioned.
Poor Straight Line Tracking SOLVED!!
Well this morning I swapped out all 4 of my end links (they were shot) ... stockers at 235k. While at it and on a whim .... I checked the torque on my outer tie rod ends .... and they were at 20ft lbs (I swapped them out when I put my rack on recently. I torqued them to 30 ft/lbs. I drove it in to work today and on the highway the straight like tracking is spot on.
While at it, I put my Founders rear LCAs back on. I'm still on the fence about the poly. I can feel the difference and not for the better - but that is another thread.
Glad to hear you're tracking straight now! That's great.
- Kevin
- Kevin
