New BMR Springs and C5 Wheels
Just fitted new BMR Lowering springs and C5 wheels, They are genuine C5 wheels so think i might need spacers, they need to come out a bit, what do you think?
I was worried the ride might be too hard but i'm impressed with the BMR springs, it's like a different car now!
IF they are stock C5 wheels (17x8.5, 58mm offset fronts, 18x9.5, 65mm rear), then you can safely run a 1" spacer/adaper front and rear with out issue. The fronts would then have a 33mm offset which works well with a wheel that is only 8.5" wide - the rears would be 40mm which, again, is almost perfect for a 9.5" wheel. Again IF they're stock C5 wheels...
LS1Tech Premium Sponsor
The car definitely has a nice stance and it may settle a touch more over time. The nice thing about the BMR lowering springs is that they give the cars a nice stance without sacrificing too much ride quality or ground clearance. We are glad you are happy with your BMR parts!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
