Bmr torque arm install?
Old 10-05-2012, 11:40 AM
SVTTHIS's Avatar
Default Bmr torque arm install?
Ok it's in the car but anyone have luck getting the factory clam shell around the urethane mount and getting that bolt back through I'm having a bit of trouble with mine thanks guys!
Old 10-05-2012, 12:49 PM
need4fun2469's Avatar
I had to trim some of the poly mount in order to get my clamshell around it.
Old 10-05-2012, 01:54 PM
SVTTHIS's Avatar
Oh awesome thanks ill give that a try!
Old 10-06-2012, 04:26 PM
szalkerous's Avatar
I'm in the middle of dealing with this myself, I just reached up with my head pointing out from the driver's side, one hand pinching the shell, the other trying the thread the bolt in. This was the only way I could do it.
Old 10-08-2012, 04:17 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Generally you won't need to make any further modification than what we list in our installation instructions, but I guess some guys may need to do a little more to get the bushing to mount correctly. If there is material still inside the factory clamshell, remove that before touching your new polyurethane bushing.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 10-13-2012, 10:42 PM
10 Second Fun Car
jlrz28's Avatar
BMR Tech2, Can you please clean out your PMs? I would like some info on some front suspension parts.
Old 10-15-2012, 10:26 AM
BMR Tech2's Avatar
Opps, sorry about that. I got it clean up a little so we should be good. I want to say it used to unlimited storage for sponsors? haha
You may also email me at kevin@bmrsuspension.com
Thanks,
Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 10-15-2012, 12:16 PM
ORedRoc4's Avatar
Is it easier to install with the suspension under a load? Im going to try it tonight without a load and hope to be able to get a thread or two started. Im having the same damn problem...
Old 10-15-2012, 01:52 PM
BMR Tech2's Avatar
It makes it easier, in my opinion, to install the TA with the suspension loaded. I realize this isn't possible for many driveway mechanics, but you can install it unloaded if need be. It must adjusted loaded, though.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 10-16-2012, 08:15 AM
camarokid91's Avatar
The hardest part is getting the old bushing out the rest is pretty simple, you might want another set of hand to help out when putting the new one in.
Old 10-16-2012, 11:48 AM
ORedRoc4's Avatar
I got mine in last night, I just put 2 jack stands on the 10 bolt so that the suspension was loaded as it were on the ground. I had an extra set of hands to help compress the clamshell on. Eventually it slid right in. I don't even know why it was so hard in the first place.
Just one of those things that you have to leave and come back to a day or two later and it works magically like it should lol...
Old 10-18-2012, 07:54 PM
rabbit320's Avatar
i have a small write up with pics when it comes to that exact problem... search under " bmr torque arm , new pix how to install " in the suspension section, mine was with an m6 trans... pretty much i put the clamshell mount on, without the bushing, trimmed in certain places as seen in my thread, then lubed the bushing and pushed it in.
i was also worried that a lil sensor plug would rub the very edge of the tq arm on the trans housing, but i dont think it has, something you may want to dremel/grind out while your there
Old 10-19-2012, 08:45 AM
BMR Tech2's Avatar
Glad to see a lot of people aren't having too much trouble installing their BMR Torque Arms. It's a very straight forward install, if you ask me, and our instructions explain it pretty well. I would love to have more pictures showing the installation process, but we actually don't receive too many calls about installation help.
- Kevin
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old 10-19-2012, 04:22 PM
10 Second Fun Car
jlrz28's Avatar
Just got mine back together last night and set the pinion angle this morning. Not too bad of a re-install (I didnt do it the first time).
Old 10-19-2012, 07:19 PM
bwkmaro's Avatar
i just left mine on top of a engine for a hour so it was warm the poly bends and moves much better takes all of 5 mins after its warm
Quick Reply: Bmr torque arm install?
