Found GM Part Numbers for rear spring Insulators
Old 10-09-2012, 09:21 PM
Heat Seeker WS6's Avatar
Default Found GM Part Numbers for rear spring Insulators
Hope this is useful to others.........
I needed to replace the rear lower spring isolators since they were worn to just about nothing. I also replaced the passenger side upper isolator since it had a split.
After ALOT of chasing around I finally found them and here they are for EASY future reference for those who want to use the OEM replacements. According to the dealers I called, they don't even show a lower one even used on the F-body's...Nobody could explain why.
Rear Lower Isolator: 10247105
Rear Upper Isolator: 10290379
Old ones that came off my car...
Old 10-10-2012, 07:04 PM
02TransAm/Batmobile's Avatar
I never knew there was a lower spring isolator.
Old 10-10-2012, 07:28 PM
jbridwelltransam's Avatar
I never knew about a lower one either?
Old 10-10-2012, 08:44 PM
ssteven's Avatar
I bet the lowers help with the sqweek.
Old 10-10-2012, 09:39 PM
Obviously I cant say all have them, but mine certainly did. Dealers, napa, Autozone etc & etc couldn't find the pn for that lower. I was able to id only partial pn's on each one that came out and actually had to guess on a digit. Sure enough, with the patience of a local dealer, we found it. Total pita this was
Old 10-10-2012, 09:53 PM
sokr915's Avatar
Is this only for LT1 cars?
Old 10-10-2012, 10:19 PM
I don't know. Although mine is an early 93 lt1
Old 10-11-2012, 09:55 AM
themealonwheels's Avatar
Wow, people actually seek these? I would have given you two sets if you paid shipping... LOL!
Quick Reply: Found GM Part Numbers for rear spring Insulators
