Ground Control Coilovers - Same for Koni vs. DeCarbon?
Old 10-10-2012, 07:48 AM
therealcreeper's Avatar
Default Ground Control Coilovers - Same for Koni vs. DeCarbon?
I'm getting beat up driving my car lately, switching back to stock springs/shocks for a while. I have GC coilovers on my front Koni's, wondering if I can use them on my stock shocks. I know the perch from my stock shocks will fit on a Koni shock, is there anything different between the design for the coilover kit between stock and koni?
thinking of running a 350# spring rate and a hair of a drop so it's not stock 4x4 height
Old 10-10-2012, 08:16 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Are you sure you can get the GC parts off of your Konis without damaging them? When I had them on some Bilsteins, they were pretty much a press fit on there, so they weren't budging without some serious work.
Old 10-10-2012, 08:18 AM
MeentSS02's Avatar
Actually, now that I'm thinking about it, why are you even considering going back to Decarbons? Just put the lower rate springs on your Konis, raise it up a bit if it is too low (which can often cause a lot of ride issues), and do the same out back?
Old 10-10-2012, 11:14 AM
I've removed them before, I put a thin layer of grease inside the sleeves so they wouldn't seize to the body. I have 600# springs on the front Koni's, and the adjusters are both frozen on one of the highest settings. One of the threads may be screwed up also (I put an extra nut on top of it) so if I take them apart I don't know if I'll be able to salvage it.
I plan on keeping the Koni's in the rear. I got a set of 10k mile front DeCarbons for next to nothing, and I honestly don't have $200 for a set of front Bilsteins right now. I have BMR spings out back so possibly selling those and the Coilover/Koni setup as is. If I can use the coilovers maybe I'll keep them and eventually buy a new set of Koni's someday.
Old 10-10-2012, 12:48 PM
MeentSS02's Avatar
I've got a set of Bilsteins with the Ground Control Adjusters sitting around at home somewhere...not in the best of shape looks-wise, but are still functional (at least they were when I took them off a few years ago). Doesn't sound like you are in any position to buy them, but just throwing that out there. They certainly aren't doing me any good at the moment.
Old 10-10-2012, 01:00 PM
00transamws6's Avatar
Do you want to stay with the adjusters or a fixed ride height? I have the SLP/Bilstein/Eibach and my setup seems pretty comfortable. That could be an option and it doesn't lower it too much either.
Old 10-10-2012, 06:50 PM
thanks guys, I really don't have the cash for either option though. I've had the slp bilstein/eibach combo, I thought it was a pretty nice middle of the road setup. I would like to get front Koni's again in the future with stranos or stock springs, but with the adjusters broken I really can't change to a different spring or adjust it for a smoother ride, so stockers it is for now.
I'll try emailing GC but haven't heard the best things about their customer service
Old 01-07-2013, 09:09 AM
xela nirvash's Avatar
Talking GC coil conversion kit
sorry bout that creeper,but u seem to have used the GC kit on your trans am!and well i am in the process of ordering the GC coil conversion kit from GC;and i have a 1998 trans am STOCK.
i want to ask
is this a good price and all for this kit
because i use my car for just daily driving street no track or drag
i can feel every bump in the road i believe is time to replace the shocks and spring
any how this is what GC sent me
98 Firebird
2510.02 93- Camaro/Firebird w/ Koni
Height Adjustable Spring Kit 10/450-GCCAM
1 $415.00
GCCamRR Camaro Rear Spring 2 1.00 2.00
Koni Single adjustable strut*8241 1139Sport 1 $460.00 2$920.00
30% Off discount -30.00% -$276.00
Koni Single adjustable shock*8241 1140Sport 1 $252.00 2$504.00
30% Off discount -30.00% -$151.20
Quick Reply: Ground Control Coilovers - Same for Koni vs. DeCarbon?
