subframe connectors
The coil would compress if it were overly soft, or you had a huge amount of leverage on it, but otherwise the car just lifts (note: not flexes) on that side.
-You can flip the argument pretty easy here, do the same to the rear where the springs are significantly softer, and its a 1:1 motion rate of spring compressing to wheel travel. You'll see the rear axle compressing quite a bit and the body not moving. Does this mean the rear chassis of the car is stiffer? Nope, the spring is just softer and will compress under less weight.
But im not sure where you are going with this anyway, as it has nothing to do with how the car will behave to a bump or weight transfer in the real world. Bumps are not some gradual lifting of the suspension, they are quick, high rate hits. If things were flexing as bad as you thought, then glass/fiberglass and plastic would be breaking left and right, bolts wouldn't fit/would be bending, and getting an alignment would be useless as the car would just be flexing anyway.
Rear quarter panel dimples.
I've never took my SS to a drag strip, nor to any autoX events, just daily driven with runs thru the southern Cali canyons every other month.
Personally I feel I wasted my $$$ but hey, it's not like I'm going to take them off of the car now.
got the welded ones from LG Motorsports, had the v-braces bolted on, and it did make a huge difference but then again the suspension was totally factory, no SLP options so I had the SS 32mm (31mm?) front sway, deCrapper shocks, factory springs, everything else was factory.
AND, rear quarter panel dimples AFTER I had the SFC's welded on, it took a few years but bottomline they showed up.
GM Quality I guess.
You must have the loosest 4th gen around... Has it been in an accident?
I have done this and my car did exactly what I described. The coil didn't compress but that side of the car picked up.
