5th gen Brembos on 4th gen with C5Z06 wheels install pics
#81
5th gen brake rotor and caliper interchangability....Great to know!
I put CTS-V 6P calipers and rotors on my 5th gen camaro....bolted right up!
That means that I can do the same with my 4th gen.....as long as the 6P fits inside the wheel....but it should right? I have Z06 18s on the front...and they came with 6P calipers......
And the 6P calipers are cheaper than the Camaro 4P ones on Amazon.....
$270 vs. $320
Has anyone seen 6P CTSV cailpers on a 4th gen?
$270 vs. $320
#86
I flushed the whole system but unfortunately didnt know about the damn abs module that can only be bled through tech II software so still have to find somewhere to take it to bleed that as I still get weird pedal feel before the brakes heat up
#89
Do you know if the rear calipers on the 5th gen will fit the rears of a 4th gen
Long time lurker so thought id give back. I decided to do the front Brembo swap on my 01 camaro. I had a little trouble finding all the info i needed so figured I'd start a thread with all the parts required and their prices along with pics. 18x9.5 front C5 Z06 wheels do not require wheel spacers
Parts Required/Used
-2010 camaro Brembo front calipers (make sure spindle/caliper bolts are included)- 250$ from Cleveland Pick Apart (http://stores.ebay.com/Cleveland-Pick-A-Part)
- Brake lines from kore3 Industries- 55$
- 14" 2010 Camaro SS rotors from ebay 150$
- Have the inside bore of the rotors machined to 70.7mm by local machine shop - 40$
- Hawk HPS pads- 113$ on ebay
- I had calipers painted red with white Brembo letters- 40$
- 9/16 drill bit- 15$ from Home Depot to drill out holes in the spindle
Really as simple as removing your old calipers and rotors, drilling the spindle to 9/16" holes, replacing the brake lines, putting on new rotors, bolt calipers on (the bolts thread into the calipers)
**NOTE** 18x9.5 C5 Z06 wheels do NOT require wheel spacers
Hope this helps and feel free to PM me with any questions
test fit
Parts Required/Used
test fit
