New! Viking Double Adj. Front Coil Over kit Available at UMI!
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
Double Adjustable Front Viking Coil Over kit for the 93-02 GM F-Body
Price- $549.99 per kit
Viking's double adjustable front coilover kit for 4th Gen F-bodies provides ride height adjustability, in addition to compression and rebound adjustability, all in one convenient package. The shocks feature 19 independently adjustable compression and rebound settings for a total of 361 possible valving combinations. The 2-1/2” diameter springs are available in a wide variety of rates from light drag race to extra heavy auto-x and road race. They are a direct bolt-on and can dramatically increase the performance of your car in a variety of situations. No tools required to optimize damping for street, strip, auto-x or road race. - simply click the adjusters by hand. Ride height is adjusted via spanner wrench and requires a few minutes per side. Thrust washers and spanner wrench highly recommended. Sold per set.
More Information and Direct Link to our Website Here
Value Added Features:
Direct bolt on replacement for your vehicle.
19 way adjustable compression and rebound damping allows tuning for strip, street or handling (361 possible combinations)
Every shock is built, dyno tested and serialized in Lakeville, Minnesota
Shocks can be rebuilt at Viking or an authorized Viking rebuild center (call for details)
Standard 2-1/2” ID spring with a wide variety of spring rates available.
Springs are lightweight, high quality, Made In USA.
Kit Includes:
(2) Front coil over shocks, double adjustable
(2) Front springs with choice of 250, 300, 350 or 550 spring rate
Kit Includes:
![](http://www.umiperformance.com/catalog/images/large/A206a_LRG.jpg)
![](http://www.umiperformance.com/catalog/images/large/A206ab_LRG.jpg)
Glad you asked! The Vikings are 19-way adjustable in both compression and rebound. Basically the adjustment range is pretty wide.
To simulate a heavy compression R series QA1 you would turn the rebound down to a low number (1,2,3 or so) and turn the compression up to 13,14,15. This allows a wheelie car to drop the nose and not get into the bump stops. You can really control the landing nicely.
Feel free to contact us with any questions or what fits your application.
Thanks for looking,
Ryan
We are also offering a rear double adjustable shock from Viking and a full front and rear kit that includes four shocks, two front springs and the spanner wrench/thrust bearing kit.
Rear Shock Information Here
![](http://www.umiperformance.com/catalog/images/large/B220a_LRG.jpg)
Complete Kit Information Here
![](http://www.umiperformance.com/catalog/images/large/VTK206a_LRG.jpg)
What's the eta on a coilover kit for the rear? I'm either about to purchase the full kit, or buy the fronts and wait until you guys come out with the rear coil over kit.
