Strano Springs
So I got my springs in a few weeks ago. It dropped the car about 3/4 of an inch (I good with that) my question is do I need to get alinged? And if so any special specs? I have been hearing 1-3 neg camber is good? and if it is, wouldnt I be there by lowering the car? and what about the rear bump stops? Cut em down? remove them? Buy shorter ones?
-3 would be too much, but I don't you have to worry about that. You'd need to add parts to get that much offset. With stock bushings and control arms, you will probably end up around -1. That's good for a well balanced street/performance setup. The tire should wear evenly.
