new shock and spring package
Old Mar 6, 2013 | 10:02 PM
superman2002's Avatar
Default new shock and spring package
I have 2002 camaro that I drag race and Autocross. Plan is to do some road racing.
It is currently putting out 530hp at fly. My question is what is a good shock and spring setup to do all 3 or am I going to switch setups evertime. Right now I have bmr springs 550 in front 230 in back. Any input would be appreciated.
Old Mar 7, 2013 | 11:20 AM
CamaroFreak's Avatar
Koni/stranno set up
Old Mar 7, 2013 | 04:14 PM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Check out our Koni/BMR sale with free BMR Lifetime Warranty springs.
BMR/Koni Shock Value Sale
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Mar 8, 2013 | 06:00 AM
JustAFooL's Avatar
I've always used bmr products and I've never had any complaints. I'm actually swapping front springs right now, car had Hotchkis. I don't think though that you will find the best package for both worlds though, totally opposite things in going straight and the twisties..
I am somewhat disappointed in bmr this time though. Bought new springs and didn't get any stickers! Wtf??
Old Mar 8, 2013 | 08:33 AM
BMR Sales2's Avatar
Your are not going to find a shock and spring setup that will be really good at drag racing, autocrossing, and road racing. You kind of need to figure out what area you want to concentrate on and stick to that so you can have an area the car is good at rather than being mediocre in all three. The BMR spring will work well for autcrossing and road racing and will be decent for drag racing but with lowering the car you make it a bit harder to transfer weight. What shocks are you currently running on the vehicle?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Mar 8, 2013 | 11:56 AM
Blackpanther99's Avatar
Definately look into the Koni shocks with the BMR springs package. Its a great quality deal.
Old Mar 12, 2013 | 08:56 PM
Default replies
I already have bmr springs on stock shock. I does pretty good in the autocross and road coarses. It does have alittle problem with weight transfer at the drag strip it runs low 11s right now. I was hoping with some adjustable shocks it would help with that problem. And as far as picking 1 at of 3 thats not going to happen. I do all the work myself so its not a problem to have multi shock and spring package. Sorry I havn't replied back dont get on here much.
Old Mar 12, 2013 | 09:21 PM
slow ride 02's Avatar
Adj 4/4 Koni's with stock springs, Strano's sway bars front and rear. Disconnect the front bar and adj the shocks for the drags.
Old Mar 13, 2013 | 09:08 AM
BMR Sales2's Avatar
No problem, with the factory shocks and our BMR lowering springs I could definitely see you having issues with weight transfer. A good cheap quick option may be to throw some cheap Competition Engineering 3 way adjustable rear shocks on the car and see if that help, they are less than $100 and are easy to install. Also removing the front sway bar while you are drag racing will also help with weight transfer so if you don't do that I would definitely recommend it.
Setting a car up to work well in autocrossing and roadracing is pretty easy because many of the key variables are the same where as everything is way different when it comes to drag racing.
I think the Koni shocks give you the best chance of performing well in all three areas but they are definitely a more handling oriented shock so I am still not sure if they would perform up to your expectations at the dragstrip. What I can say is that they should definitely perform better at the dragstrip than the factory Decarbon shocks do.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Mar 13, 2013 | 12:34 PM
Thanks for the input I think 4/4 koni for now and maybe a set strange or qa1 later for the bigger drag events
Old Mar 13, 2013 | 12:56 PM
BMR Sales2's Avatar
If you decide on the Koni F4/F4 you can order them directly through us at the discounted price and you will get a set of our BMR lowering springs for free which you can sell to make a little money back. It is really an awesome deal.
__________________
Glenn ***
Sales Tech
813.986.9302
