Panhard bar/relocation install?
Old Apr 30, 2013 | 11:45 PM
Dchia's Avatar
Default Panhard bar/relocation install?
Just ordered an adjustable panhard bar + panhard relocation from Founders (super excited on them), and I was wondering if this was something I could do in my garage on a saturday or if I should bring it in to my mechanic. Couldn't really find any write ups, just to get that out of the way. Thanks, all!
Old May 1, 2013 | 01:01 AM
sjsingle1's Avatar
so easy......a cave man could do it
Old May 1, 2013 | 01:46 AM
94 White T/A's Avatar
Its all bolt in isn't it? thinking it should be no big deal
Old May 1, 2013 | 03:10 AM
Dchia's Avatar
Yeah it's all bolt in. But it all came with some brackets and I'm not quite certain how they mount. I'm one of those people who are really skeptical of my abilities when it comes to DIY stuff.
Old May 1, 2013 | 03:24 AM
Don't be scared, I think it will only line up one way, there's only one way to learn. There are plenty of pics on here that have relocation, just search it if you need. The true dual thread has a bunch too because they are needed
Old May 2, 2013 | 04:01 AM
99Bluz28's Avatar
I'd recommend getting the Jegs PHB relocation brack that welds onto the rear-end PHB mount; especially if you car is lowered.
https://ls1tech.com/forums/suspensio...g-bracket.html
Old May 2, 2013 | 09:34 AM
z28bryan's Avatar
You're words are hurtfull and you will not see me at the pancake social this Sunday.
Old May 2, 2013 | 09:35 AM
z28bryan's Avatar
Is it the PHB relocation thing that just seems to be for exhaust clearance that UMI/BMR make? Comes with the PHB upper support bar. Or is it the single bracket that has like ~4 holes in it that you can add to both the chassis and the axle side?
Old May 2, 2013 | 10:34 AM
WS.666's Avatar
Here's a pic of mine to how you how the brackets fit.
Old May 2, 2013 | 04:05 PM
Dchia's Avatar
^^ That looks great! So wait, welding is an absolute must? Or is there a bolt-in option?
Old May 2, 2013 | 04:56 PM
MasterTomos's Avatar
A mass majority of people just do the bolt in option. That's what you ordered. It's really easy, just nuts and bolts.
Old May 3, 2013 | 12:01 AM
Dchia's Avatar
Just the way I like it, haha. Thanks!
Old May 3, 2013 | 09:41 AM
WS.666's Avatar
Mine isn't welded. It's bolted in.
Old May 3, 2013 | 11:07 PM
Dchia's Avatar
One more thing; whats the deal with the bushings? I heard they needed to be lubed/greased before install. What kind should I use and how much?
Old May 19, 2013 | 07:04 AM
AmDWs6's Avatar
can some1 please shed more light on this matter, i'm just as lost as the OP.
Old May 19, 2013 | 05:33 PM
99Bluz28's Avatar
IMO, there's only one way to do it correctly especially if your car's lowered , that's to lower the phb mount on the axle tube at the same time as you lower the body mount point.
Old May 19, 2013 | 10:01 PM
ChrisRZ28's Avatar
PHB is lowered, but PHB brace is in stock location. Exhaust over the axle is still stock. My understanding is you would use a lowered brace for dual exhaust. My PHB is lower then the axle tubes, but not lower then the diff. A lowered PHB is the same as using a watts link, just not as easy to 'tune' as a watts, and a lot cheaper.
Attached Thumbnails Panhard bar/relocation install?-002.jpg   Panhard bar/relocation install?-004.jpg
Old May 20, 2013 | 12:43 AM
99Bluz28's Avatar
ChrisRZ28 , so what's your reason for lowering your phb....?
I've been trying to figure a logical reason, but I can't find one.
Old May 20, 2013 | 12:55 AM
SparkyJJO's Avatar
No it isn't, because the panhard still swings in an arc, making the rear move left and right as the suspension moves. A Watts has zero left/right motion.
Old May 20, 2013 | 04:25 AM
Reaperchild's Avatar
Easy Install true ... unless its your relo Bar to fit !!
My Founder PH Relocation Bar is short by almost 5-8mm & wouldn't reach the 3 Top Bolts =( ... I will have to twist my Chassis (Relo Bracket Area) to the inside to get them to fit the 3 bolts on the driver side.
One more thing ... is the PHRelo Bar supposed to hit the Fuel Tank ?? (Another Nightmare from Yesterday)
