Best way to get an ABS scan?
Old Aug 2, 2013 | 09:38 AM
Midnight02's Avatar
Default Best way to get an ABS scan?
Since my recent track day, the ABS Inop and ASR off lights have been on constantly. Checked the wheel speed sensors and looked for bad wiring and couldn't find anything, so now I would like to find a way to read the codes.
According to most of the threads on here, AutoZone will read these for free, however I've been to three different locations in the Atlanta area and even called corporate customer service only to be told they do not scan for ABS codes.
So far it looks like my options are to either pay a shop to read them or spend a boatload of cash on a tech II scanner -- neither of which are great options. Given that I track the car pretty regularly, it would be nice to have access to a tool to read the codes. Any thoughts? Any luck with Advance Auto Parts, Pep Boys, etc?
Old Aug 2, 2013 | 04:06 PM
Nathan C's Avatar
How long has it been on? When I had my Formula dynoed it came on for a while and then went off again.
Old Aug 2, 2013 | 05:13 PM
ajwoodtransport's Avatar
Don't really know these cars very well, but did you or can you check the tone rings for contamination? That's a common problem on other types of vehicles. Good luck.
Old Aug 2, 2013 | 10:48 PM
libertyforall1776's Avatar
Advance Auto scans them for free, ask me how I know.
Old Aug 2, 2013 | 11:01 PM
camarokid91's Avatar
I just went through this it sucks trying to find one. Sullivan tire wanted to charge me $99 dollars for diagnostic. I walked out since you can buy the scanner for $150.I ended up posting on Facebook and a friend had one. You should try reaching out on social media or forums in your region you never know what you will find. Good luck.
Advanced and Autozone do not do ABS codes in MA, I went to several locations trying to get it done.
Old Aug 2, 2013 | 11:41 PM
01ssreda4's Avatar
Auto parts store scanners don't read the BCM, which is what controls ABS. Anybody who mentions an auto parts store from here on out will be talked badly about to no end You must find a dealer or independent shop with a Tech type scanner Period. There is no other way to access the BCM. Your alternatives are 1. pull and clean each wheel speed sensor and hope that is a quick fix (they get dirty often), or 2. do an ABS delete.
Old Aug 3, 2013 | 07:41 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
I live with these codes. My frickin gauge cluster looks like a Christmas tree at night sometimes.
ONLY thing holding me back from an ABS delete is not doing enough research on proportion valve adjustment.
Old Aug 3, 2013 | 09:02 AM
LPE 403's Avatar
Lmao....x2. Put the first 100 street miles on this car since completing the build and didnt think any more lights could come on until I hit the freeway. "ABS INOP"
Old Aug 4, 2013 | 01:41 AM
01ssreda4's Avatar
Do it!! Should have mine bled and back on the road early this week. Can't wait to bleed with no freakin ABS block in my way.
Old Aug 5, 2013 | 03:39 PM
Midnight02's Avatar
It's been on ever since the track day. Hasn't been intermittent -- it's been on constantly.
Checked and cleaned the wheel sensors and had no luck there.
I understand that reading the codes may still not yield a simple fix for the issue, however I'd love to know which direction to start with.
Not interested in the ABS delete option because the car spends a lot of time on road courses. Certainly nice having ABS out there.
Old Aug 5, 2013 | 03:46 PM
Midnight02's Avatar
Any chance the Equus 3150 scanner will read our codes? It claims to, however I've always read that it takes a Tech II scanner to get the ABS codes from these cars. Anyone have any experience with this?
Old Aug 5, 2013 | 03:55 PM
Post
They do in IL, Advance Auto here has the Actron CP9580A AutoScanner Plus, which you can buy for <$187 shipped online… Yes this scanned pulled my code from my '01 SS, just fine.
Phone first, before you go!
Old Aug 5, 2013 | 03:57 PM
You Sir are just flat out wrong. There are plenty of aftermarket scanners that read ABS… AutoXray and Actron to name two…
Old Aug 5, 2013 | 05:40 PM
dr_whigham's Avatar
The Scammer Hammer
He's talking about the general run of the mill places. SOME will have a nice one. It's hit and miss. NONE of the Advance, AZ's, O'Reilleys, Pep Boys around me have a scanner that can read ABS codes.
Old Aug 5, 2013 | 06:29 PM
You can get this ABS scanner ('96 & newer cars) for $80 shipped online if you have an iPhone or Android device:
http://www.actron.com/product_detail.php?pid=16367
Old Aug 6, 2013 | 04:32 AM
01ssreda4's Avatar
Well thanks for adding relevant info. I could care less as my abs is in the bushes. I will make a note for future threads though.
Old Aug 8, 2013 | 12:14 AM
joecar's Avatar
The Actron scanners that specifically mention ABS are do read ABS codes (as libertyforall said above)... these are what some AutoZone store loan out (for refundable deposit).
Same with AutoXray (the one that mentions ABS).
EFILive tuning package reads ABS codes (actually it reads and clears codes for all modules on the serial bus).
AutoEnginuity reads ABS codes and can do bidir with the ABS controller (requires GM Enhanced option).
Old Aug 8, 2013 | 12:54 PM
Midnight02's Avatar
Thanks for the info above. I did some research and confirmed that the $150 Equus 3150b will read the ABS codes for our cars. Think I might give it a shot. Would rather drop $150 on a scanner then pay someone $100 to plug it in and tell me what's wrong!
Old Aug 14, 2013 | 06:43 PM
BRUTL's Avatar
actually, abs is controlled by the Electronic Brake Control Module, or EBCM, which is the big control unit located on the actual ABS pump/Solenoid pack. But still, most autozones have a simple obd II scanner that is only good for engine codes. A snap on eithos or greater scanner can read everything you need access to, too bad you aren't close to me, you could use mine.
Old Dec 5, 2013 | 10:46 AM
Midnight02's Avatar
Thanks BRUTL. Ironically, I grew up in Elizabeth City, NC and given that there isn't much to do there we had to go to Norfolk or Newport News for dinner/movie/shopping/etc. I head up there frequently however since I have a little guy we always travel in the wife's SUV and the SS stays in Georgia.
I just bought the Innova Equus 3160d scanner off of Amazon for $159. Found a lot of other info online and it seems this should be able to help diagnose the ABS issue. If it works, it should prove to be a helpful tool to have around (especially when you encounter brake issues at the track). Sucks losing part of a track day because of what could be a relatively simple issue to fix.
