I'm Afraid of My Car
#62
FYI, even having poly on one end of the lca's will limit articulation(been there, done that). I'd recommend going with the roto-joints on both ends, you'll have more predictable handling at your limit of your tires. Have you tried any different shock settings, do you have your watts-link dialed-in?
#64
So are you saying that your shocks are still set to full soft...? The front's really need to be turned up at least 1/2 way with the 550 lb.in. spring rate, full soft(or close) on the rear is fine .
