F-Body Rear Suspension Build
could you post some pics of the front of the TA and the TA relocation bracket. also how low does the TA relocation bracket hang down. my car is lowered 2.25 inches so that is a real problem for me
Now the TA might be an issue since you are so lowered so much. Right now I'm 0.75" from the highest setting on the TA Relocation Mount. Since the car has 1.25" lowering springs, you are going to have pinion angle issues. Not to mention my TA barely clears the fuels lines above it. With it adjusted up anymore, the TA would definitely hit those lines... no bueno. Unless you wanna re-route hard fuel lines and use a BFH on your floorpans.
You should probably call the sponsor you're purchasing them from and see what they say before dropping the cash on this setup. My $0.02.
