Took tcs, abs and cc off. Have a question now
I had the motor out of the car and decided to pull some dead weight out that I never use. I took all three out and used the sjm abs delete kit. Now my question is, since I took the tcs off, will I have any problems with it? I basically just pulled the unit and that's it. Don't want the tcs but don't no if I need to do anything else
Yep, besides having a crap-ton of lights lighting up your dashboard now it will work great with a non-tcs throttle cable. I believe I paid roughly $20 for an OEM unit, new, and it only takes about 5 minutes to swap it in.
In short, no, they aren't bulbs they are LEDs soldered to a circuit board. When you disable TCS nothing happens. When you delete abs, I got Brake, SES, and ABS lights. Basically, you remove your gauge panel, pry it apart carefully, then cover the LED with black tape or something of that nature and put it back. Then no more lights.
did you ever happen to scan it? and has this ever happened to anyone else?
