effect of lowering only the front??
So I have a 2001 z28 lowered on the bilstein shocks and springs kit. Im considering replacing the rear bilsteins springs with the stockers which should raise the rear 1 to 1.5 inches back to stock height. Is this going to cause unpredictable over steer?
Also I may need a panhard bar. Car has zo6 replicas wrapped in fat f1 goodyear tires and the rear driver side rubs fenderwell on cloverleafs. Will raising the rear back to stock height eliminate the benefit I may see from an aftermarket panhard?
Thanks guys
We have a few cars with rake, similar to what you're describing. Doesn't seem to hurt anything when driving in our normal manner.
Your results may vary.
Any of our adjustable PHB's should be able to accommodate whatever rear height you're at.
ramey
Thanks guys
Why do you want to raise the rear? That is going to be pretty a huge amount of rake. If anything I would think that would cause more understeer.
If you want to eliminate the rubbing issue with the wheels you can do the BFH mod + an adjustable PHB or more ideally a watts link (more $$$ though, but won't have the rear end moving in the arc motion anymore).
If the rake is going to be too extreme may just get some lca relocation brackets, lca's, and an adjustable phb. I'd rather have my *** drag a little then slam the nose every time I leave or enter a driveway.
If you want to eliminate the rubbing issue with the wheels you can do the BFH mod + an adjustable PHB or more ideally able watts link (more $$$ though, but won't have the rear end moving in the arc motion anymore).
Big F*cking hammer mod. You "massage" the inner fender wells where the tires hit for clearance.
As stated, there's a few clear spots where the rear rubs, just massage it with a hammer and you'll be good. Don't forget to undercoat the area you hammer as you will probably chip off some of the factory undercoating.
Chris,
In track conditions, softening the rear end I noticed tends to allow the rear to stick a little better but at the cost of the feel of the car. Something too stiff can make the car easier to handle when it sticks, but harder to keep control of after it enters a drift. The trick is to get a good balance of everything. Its definitely more complicated than what I've written.. but these are the things you have to think about.
Snap oversteer can either be caused by something way too soft or way too stiff. Too soft would mean the car transfers weight and roll too quickly and hits its suspension limit suddenly. A car too stiff is already acting like it's at its limit.
. Sound like a plan?
