UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid
Bolt-in Rear Coilover Brackets for the 1982-2002 GM F-Body
P/N 2047 priced at $39.99/set
UMI Performance, Inc is proud to introduce our P/N 2047 GM F-body bolt-in rear shock relocator kit. This kit rotates the factory style rear shock to reduce the common problem of lower shock mount binding. The shock is relocated to a double shear mount and pivots freely about the lower bolt. An innovative, TIG welded lower bracket holds the shock in double shear and works with standard axle mounts as well as with most common relocation brackets (spacers included). Drilling two 3/8” holes is required (no welding). The P/N 2047 kit accommodates a standard 1-1/4” wide shock mount and has ½” diameter mounting holes. Hardware is included. All UMI components are 100% manufactured in Philipsburg, PA-USA.
1982-2002 GM F-Body Rear Shock Relocation Kit, Bolt In
Hello,
This is basically a sub-component of our coil over conversion kit so if you check out the link below there is quite a few pictures.
http://umiperformance.com/catalog/in...roducts_id=783
Thanks for looking
Thanks for looking
I hope that helps,
Any bind that can be eliminated from the suspension is a good thing just don't know if these would really help, but if so it's a inexpensive thing to have. The kw's have a factory style rubber bushing end on the bottom of the shock, they also have a window adjustment like koni's do. Here's a picture of the set of mine, I don't have the car at the moment or I would measure them and see.
The car is full umi suspension components(roto/roto da lcas, full length adjustable TA w/ relocation x member, roto/poly lower A, poly upper A, and kmember)+kw coilovers+ Strano sways, and fays2 watts link.
If these will work with the kw's then I'd like to get a set to eliminate any potential binding issues the stock setup may induce.
