polyurethane bushing replacement help
Old Sep 7, 2014 | 09:13 AM
Double J's Avatar
Default polyurethane bushing replacement help
Can anyone tell me which size bushings these are or a link to purchase these or oem rubber, as you can see one has dry rotted and cracked (down side of poly bushings-no give just bind) THANKS IN ADVANCE
Attached Thumbnails polyurethane bushing replacement help-20140903_110458.jpg   polyurethane bushing replacement help-20140903_110413.jpg
Old Sep 7, 2014 | 10:13 PM
fleetmgr's Avatar
They have them hanging on the wall at my local O'Reilly's. They're called sway bar end link bushings.
Old Sep 8, 2014 | 03:30 PM
99Bluz28's Avatar
The hole size will depend on the bolt diameter so measure it.
You should be able to find the sway bar end link bushings at any auto parts store in your area.
Old Sep 8, 2014 | 04:01 PM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
If you are unable to find the end links locally let us know because we do sell the end link by themselves so we could get you taken care of.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Sep 16, 2014 | 05:14 AM
Double J's Avatar
Thanks to all ☺
Old Sep 16, 2014 | 08:45 AM
Double J's Avatar
Thanks ,is it an easy bolt in swap? Does it require a new alignment once replaced?
Old Sep 16, 2014 | 09:41 AM
BMR Sales2's Avatar
It is super easy to change out the sway bar end links and it will not require an alignment. Just swap them out and you will be good to go.
__________________
Glenn ***
Sales Tech
813.986.9302
Old Sep 17, 2014 | 08:31 AM
Double J's Avatar
Thank you, ordered kit yesterday from your company :thumbsup:
