My car is too low...
I am hating how far my car is lowered.
It appears to be about 3 inches lower than stock and it "bottoms out" constantly (no subs or extra weight in the back).
How difficult is it to raise it front and back about 1.5"?
Thanks,
Brent
Thanks,
Brent
LS1Tech Premium Sponsor
It would be awesome if you can measure where the actual ride height is that way you have some numbers to work with. Just park the car on the flattest area you can and take a measurement from the ground through the center of the wheel to the quarter panels and fenders and let us know what you get. This will let me compare what you are working with to both the factory springs and our BMR lowering springs.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
If you have an aggressive drop on the car now, going with one of the more mild options (Strano springs or BMR) would help remedy that.
I'm running Strano springs with spacers to get an extra 0.50" of clearance and I love them. I have a plan in place to tuck the exhaust a little tighter so I can pull the spacers out and get the full benefit of the drop.
What shocks do you have? I mounted my Koni Yellows with Strano Springs on the bottom perch and the front was waaay too low and scraped on everything. If you have yellows, move the spring seat/perch up to the top spot and it'll be fine.
LS1TECH Sponsor
Also more curious about what spring are there now and how they are modified, if at all.
Hard to make suggestions when we don't know where we are starting.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
