First-Time Budget Suspension Refresh/Upgrade....Need opinions!
I would return the Moog standard vertical control arm bushing and instead get their new upgraded version:
https://ls1tech.com/forums/suspensio...l#post18375806
LS1TECH Sponsor
Those are basically non rebuildable joint like the UMI roto-joint. Yes a better idea, but if you happen to autocross your car (realizing not many do, but some do) those might not be legal in certain classes as it changes the type of bushing.
That said I will shortly have them added to my catalog too as it is a better idea.
__________________
It's not mine! woo hoo!
RJ is rebuildable, unless you might be some how referring to it within a different context (or maybe typo)?
LS1TECH Sponsor
Yes, I know that the UMI roto is rebuildable. The Moog is not.
__________________
The verbiage you used presented it in the context that the non-rebuildable Moog joint "is like" the UMI RJ. If Moog is not rebuildable, but it's also "like" the RJ, then one would infer the RJ is not rebuildable either.
The only reason I'm picking out such semantics is because many unquestionably follow your advice (not stating this in a condescending way). I'm presuming you meant to say "unlike".
LS1TECH Sponsor
And hence the problem with the internet. Pick your poison, they are like them and unlike them both.
__________________
Ahh I get your point now liberty. That problem solver bushings are like (in a nutshell) a rod end with rubber lining it so it has a quiet operation and tension dispersion, perfect for the vertical bushing in any car, I like that
LS1TECH Sponsor
I have things to do that pay my bills.
__________________
