Weird Noise from rear suspension
OK I have Founders 3-piece poly control arms and the poly on car adjustable panhard and Bilstien Shocks and BMR springs and everything has been fine for 5+ months till a few weeks ago when I began feeling and hearing this "rattle", at first I only noticed it on gravel driveways but now I can hear/feel it over most any hard bump, it feels like the rear shifting just a little.
knowing how hard it is to describe a sound I made a video the other night driving on the gravel driveway at work @0:11 seconds in the video is when I transition onto the croncrete ledge of the bridge (which is heard as the hard bump) so while the sound occurs there (along with some others, that is not the sound) and pretty much stop after the @0:27 mark after that keys and other things take over sound as I'm going to slow to notice it.
I'm worried it may be the axle bearing, you may need to turn your volume up or put on headphones, the video was shot by me holding the phone in my left hand and trying to hold it as close to the interior of the wheel well while driving with my right hand.
the first three or four seconds after the hard bump @0:11 seams to be the clearest of the sound I'm talking about.
Sounds like a bad strut...check to make sure the nuts are tight on the axle and behind the back seat..does sound like a bad wheel hub bearing like on the front but its hard to diagnose over the internet from a video...put it up on jackstands and run it or get under there and grab your driveshaft and yoke and shake it around or anything that could possibly be loose. If everything seems tight then maybe bearing in rearend...when mine went out it sound like crunching not rattling
if you listen from 0:14 to 0:20 you here 2 distinct sounds, one is the key chain rattle and the other is a scratchy sound that comes as I hit bumps (if your listening with headphones it ONLY comes up on the left audio channel).
Gonna get under it this weekend and check everything good, I visually inspected it all last week by backing it up on ramps and all the nuts and bolts looked tight but I will recheck them with wrenches. The upper shock mount is solid, thats ones easy to tell with looking at the bushing.
This may seem very basic but just from the second video the sound starts as soon as you start slowing down, which is when you start applying the brakes. The rest of your video seemed fine, but I could be wrong. Simple things seem to slip the mind, worth a shot to check
The rattling if only happens when hitting bumps sounds like struts...if its all the time even on a perfectly flat road probably bearings...the scratching noise happens from brake dust...take the garden hose and spray off the rotors good and on the pads for 5 seconds and itll stop...mine use to do that till i got ceramic then the brake dust stopped and my rims dont turn so black so fast...semi metallic and basic pads do it BAD.
I'll get back in here tomorrow night after I check things out closer.
Spray the pads/calipers really good with the hose...i use to have to do it with my moms car when she first got it but i put new rotors and ceramic brak pads and it stopped and a lot less black stuff on the rims.
