Need my car to 60'
Need my car to 60'
I need my car to 60' like its been rear-ended by a school bus@60mph..
Whats all needed? I have subframes, lower control arms, torque arm and a drag bar so far.
Panhard bar, tires, gears, driver mod if you're an M6.
If you still have the 10 bolt and aren't ready to switch to something else I strongly suggest a girdle cover, welded axle tubes, and bracing.
What's your best 60ft now ? Is your lower control arms adjustable?
LOL!!
Car is a stock block ls1 with H/C/I and a 150 shot. Built 4l60 with a yank SS3600. I just bought this car in November so no track times as of yet. I just wanna be ready to roll come warmer weather. Also the car will have a S60, spool and 3.73's
If the lower control arms are adjustable and the torque arm is adjustable you should be able to pull a 1.5 60ft. Just have to use what you already have and dial it in. Other wise look towards getting some shocks. Vikings seem to be the hot ticket..
Lots of info here:
https://ls1tech.com/forums/multimedi...pics-vids.html
Most recent, Go-Pro
At 0:25 in this one
At 1:00 in this one:
I do that now on just motor. If you 1.5 on spray something is wrong! Here's my combo:
Lots of info here:
Most recent, Go-Pro
LSX Monsters Track Day - YouTube
At 0:25 in this one
RUN WUTCHA BRUNG at LSX SHOOTOUT TEST N TUNE! - YouTube
LSX MONSTERS & BLUE THUNDER 2 RACING! - YouTube
Lots of info here:
Most recent, Go-Pro
At 0:25 in this one
car runs pretty damn good!!!
if you can plant the power you should definitely be sub 1.5 if not just turn on a few MS delay and then put the entire kit on or do a slow progressive with a set delay...also what the weight? have you scaled your car (all 4 corners)? what tires? pinion angle? are you going to shock the tires and come off tbrake? there are a lot more questions but this should get you started
What gear and tire size you have in the rear? You spraying the car too?
Going with a M@H 28" drag radial
Pinion angle is -2
No brake
LS1Tech Premium Sponsor
Like others have said shocks would definitely be the next thing I would look at if I were in your position. They will help improve the consistency and performance of the car dramatically. Having a set of shocks that will allow the car to transfer weight will really improve your 60ft times.
We would be more than happy to help you out in any way we can so just let us know.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
