PLEASE figure out this friggin noise.........
So any time I'm moving at any speed say under about 50mph....just cruising steady.......if I hit the pedal to the floor and the rear end slightly drops down I hear like a "crunch" sound. Or maybe a very hard "rub" sound. Then the car just accelerates quietly and normally. Its only when I smash the pedal down. From a dig....its a longer "crunch" sound.....
Two days ago......a visual check of the entire rear-end was done by a power train shop as they were changing an axle seal for me. They saw nothing.
Maybe a shock as it compresses....?
Bump stops have been removed....12 years ago.
Its like a "grrrrrrrrrr" sound.....like a grinding sound. Like a blender sound for just one second.....then it goes away as the car continues accelerating. Its very loud, very easy to hear.....but I cannot pick it up on my phone.....can't hear it on the playback.
Regarding my other thread about my sway bar being removed.....
******I removed my sway bar today because I lost the brackets while driving and I noticed it just hanging on the end-links.......
I was hoping that was the noise I'm hearing. So the sway bar and both end links are removed now.
Noise is the same........still there.....
So does it only make this sound when you go WOT or when you hit a bump too?
If its only when you go WOT (or any throttle input) it is probably drive train related, maybe something in the rear end itself is going bad (bearings, clutches, gears etc.)
If you get the noise on bumps then get someone to push down on the back of the car while you are under there and see if you can find the noise then. Maybe the torque arm hitting the underbody? The rear end/torque arm/something hitting the exhaust?
Unbolt the shocks from the rear and push down on the rear and see if it makes the same noise. Watch to make sure the tires are not rubbing anywhere as the rear of the car gets pushed down, a little rub can make a big noise.
Try unbolting one side of the LCA's as well and move them around in your hand and see if they are making the noise.
I was thinking maybe a shock is bad.
To your questions:
It only happens when I stab the throttle and the car wants to take off.....mostly from any speed slow enough that the rear end drops down a little when I stab it. If I'm doing 80 mph and stab it I don't hear/feel that quick grind Because the rear end doesn't drop down.
I'll check all that when I get it on my friends lift in a couple days. Thanks....
To your questions:
To your questions:
Think about it, if it were something in the suspension making the noise wouldn't it make that noise when you hit a bump, or go over a dip or something that moves the suspension?
Sounds to me like the diff is struggling to put power to both axles when you hammer the throttle. Go to an area like a cul-de-sac and do a full steering lock u-turn and see if the rear makes noises while doing that.
Hmm, that really sounds like a rear end issue IMO.
.....But if it is the rear end....then how can it be so perfectly silent and normal during every day normal driving.
Haha, you could do that. But im talking about a normal u-turn, the idea I have is the outer rear wheel will be spinning faster than the inner wheel, if the diff is messed up it may be making noise while trying to balance power to the wheels.
I'm going to check mine today.
