Banzai Enterprises Torque Arm
I am looking to upgrade my stock torque am setup. I am going with UMI's trans cross member torque arm mount. I found the Banzai Enterprises Torque Arm on eBay and it seems to be a strong piece. I usually go with UMI products but I am impressed with how it is put together. I did a search on here and their is almost nothing on this. So I am wondering have anyone used it and is it any good? Is it too strong and does not flex enough? I plan on using my car mainly on the street. But will occasionally drag race it but not much. Thanks in advance for any input!
Here is the eBay link:
http://www.ebay.com/itm/220775052268?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I highly recommend using an adjustable Torque Arm. One of the absolute main reasons many customers opt for an aftermarket torque arm is to allow adjustment for pinion angle. I don't quite understand how that torque arm linked is mounted, or if it's supplied with the proper bushing. If you purchase a UMI crossmember, I cannot by any means guarantee compatibility between that product and ours.
However, if you purchase a UMI torque arm you are guaranteed compatibility between products. As always, UMI products are 100% made in the USA and out of US material, so you know it's of the highest quality. Not to mention supporting the vendors of LS1tech! If you have any questions please feel free to call and we can go over anything you'd like.
I personally see $200 worth of dead weight but on a side note I did notice some jewelry from their other listings that my wife may like to wear at the next Ball we attend. All jokes aside I'd stick to companies that specialize in suspension items and have a long history of building quality product that works and passionate about their product.
If you have questions about torque arms feel free to contact us and we will be more than happy to answer all your questions. We have long and short torque arms available with multiple different crossmembers.
LS1Tech Premium Sponsor
Why not spend a little extra money and go with a torque arm by a sponsor here on the forum that has been proven? Also if you are going to be using a torque arm relocation crossmember you should really use an adjustable torque arm so you can take advantage of the instant center adjustments the crossmember offers.
I guess I am just a little hesitant to purchase cheaper, less proven eBay stuff when there other options out there that are only marginally more expensive.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Go with what ur wallet n heart tells u... u don't need to always buy the "brand name" ****! I have COMPLETELY stock suspension on my car, cuts 1.5 60's! Runs well, hooks great too!
I agree and disagree with this at the same time. I feel like most the popular suspension brands are popular because they work. It is awesome that your car cuts 1.5 60ft times but I can assure you that it would be more consistent and cut better 60ft times with aftermarket suspension components.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Did you have anymore questions about our torque arms you acquired about Yesterday through PM'S?
I will tell anyone, my car cut low 1.5x on Bilsteins and SLP lowering springs. I had lower relo brackets, and had a BMR torque arm with a tranmission crossmember. Thats not a lot of mods. Could I have done the same with bone stock suspension? Quite possibly, but I wouldn't want to. Stock parts really arent made for that kind of stress. When you break something and your car goes into the other lane and takes out someone elses pride and joy well thats kind of shitty. Take responsibility, learn your car, learn how its built, understand its limits, then if you want to continue to go fast build it as good as you can. It might save you, your car, and the guy in the other lane thanks you as well.
^Agreed. I cut a 1.47 60' footbraking on my old turbo car with the stock torque arm and some super awesome comp drag shocks. I'm honestly surprised the TA wasn't bent at all when I took it off in favor of an aftermarket unit (although a 1.47 isn't anything outstanding).
I myself in my younger years tried to cheap out with suspension items to only find out I end up buying them twice, the cheap set and then a quality set that actually performs the way they should. Especially when it comes to purchasing non adjustable items.
