Strano Spring Install
Thought I'd share a recent experience for anyone currently considering this mod.
Before:
After:
I've had a lot of questions lately about how the car will look after. This is a perfect shot on a white car with 16" wheels. Lower but not slammed, maintaining good suspension travel while looking better.
Again, thank you for the review.
Unfortunately I rarely see other 4th gens but I think now the ricers can appreciate that this car has had some "love" put in to it. Not that they ever tested it....
.Sweet. The whole attitude of the car just feels and looks right now. IMO the stance & handling are now on par w/ the aggressive styling of these cars.
. Thanks for the info & advise you provided. I'll be in touch soon enough about mods for next spring. Trending Topics
Had shop also put in new bung so wideband wouldn't get impacted with the new low ride height.
New alignment, set camber to -1.2. What do you guys set it to for aggressive street?
Why does drivers side look to be a little higher than passenger side? Isolators still in the rear shocks.
I dunno, maybe the spring or isolator isn't seated correctly on the left? I mean something is odd (not the springs I know for sure but you can swap them to confirm). I mean that looks higher than stock on the LR so I think something isn't seated and/or the end of the spring isn't sitting in the notch of the isolator correctly as well. That said it's not a good pic of the left. Grainy, shadowy, etc. And the drive definitely has some slope to it and with the solid axle you know how it pivots the axle under the car if the RR is on a little higher ground.
FWIW after ~100 miles I think my springs/isolators have settled in. The front fender height measures exactly the same on L & R sides. The rear has a difference L to R of 11/16", which is less than the difference when stock.
2MCHPWR The pic of your rear spring looks like it's showing the spring sitting right over the PHB. On my car the spring mounts/sits about 3-4" forward of the PHB. Is that a stock 10 bolt rear? If so I think the spring may be installed wrong which could be pretty dangerous. Maybe it's the pic angle?
But since the install yesterday, and parked in my level garage, it seems to have settled.
I just measured drivers side is actually lower than passenger side. 26.75 " vs 27.
So all good.
I'm a bit torn myself with my current setup as the car rides horrible IMHO. Not bashing as I was forewarned.
The car was completely stock in October and it has really transformed over the last month or so.
Added adjustable Panhard, new poly lower CA's, Welded in relocation brackets for the rear.
Replaced tie rod ends on the front.
Stock ride was really good but didn't look so great. So I decided to change some things to help the look.
Added Viking D/A front coilovers and Rear Viking D/A with BMR rear springs, which are suppose to be 1.25" drop. The car now rides like a straight axle Ford A model.
My thoughts after several shock adjustment are this: The front ride is now so-so acceptable but the rear is terrble (insert voice of Charles Barkley).
Rear as that's the major concerning area.
1. Put the stock rear springs back in and have a backwards looking old Gasser?
2. Buy another set of rear springs and (or) shocks?
3. Some other completely different setup?
Front as it's only acceptable not perfecto.
1. Replace all bushing in the factory front control arms, sway bar bushing, ball joints?
2. Raise the car up an 1.000" to give it more travel?
Help would be appreciated. (attached a picture for current reference)
1. Crappy shocks.
2. Cheaper springs.
3. You added parts that bind the rear suspension up (poly bushed LCA bushings front and rear of the arm.
I think 3 is the real solution. Not sure how you ended up with what you did but I find there are two ways it happens. One is that folks see "Adjustable" and think that all shocks are the same in that way and one is as good as another when in reality what you are adjusting and when changes a lot. There are some non-adjustable shocks I'd prefer to some adjustable ones. The other reason is that it's something that is "recommended" because frankly Viking has a decent margin, sells for not a lot when folks see coil-over they go stupid, and so it's something many push.
Having said all that, a lowered car is both lower and stiffer than stock. Taller softer springs ride.... softer. But put lousy shock control on even the best springs and things go to hell in a hurry. Can we make it better? I think so, I'm pretty sure of it but I won't make any promises unless you call me to talk more detail about what it's actually doing.
I'm looking forward to adding a set of Strano 35/22mm bars to my car ASAP. In the mean while I have a set of LCA relocation Brackets on the way via UMI.
Also I agree my car rides better, IMO, vs stock now. It's more connected w/ out being harsh or even rough in any way. Good to see another person happy w/ the Strano/Bilstein combo.
The Bilstein's have a place for sure I just place that slightly behind STR.T's (which weren't around when some of you guys bought stuff, and after they were they had some availability issues).
I'm just saying that for me it's dependent on what you want from the car.
