Ebay bolt-in SFC's and adjustable LCA's
SEE POST 19
I checked with a mod before making this post and will not put up links to the auctions.
I did quite a bit of searching to see if anyone has installed the Ebay bolt-in subframe connectors or adjustable LCA's and didn't find much so I thought I would post up. They're made by the same company that tons of people started buying their long tube headers when they first came out. I was originally going with non-adjustable LCA's from another company, but when they tacked on shipping they no longer became a deal to me so I kept searching and came across the package deal on Ebay that included adjustable LCA's and bolt-on SFC's for ~$220 shipped to my door.
The box was well packaged with molded foam and all hardware included was bagged. The LCA's are a dark red color and the subframes are black. I was SHOCKED at how heavy the SFC's were. I've been around F-body's and installed or seen them installed on plenty of cars and these were by far the beefiest I've encountered. They came with all mounting hardware and coated brackets that slide up inside the frame rails with welded nuts attached to them to make bolting the front on straightforward. The rear of the SFC's uses the same mount as the front LCA mount. Hoping to install all of this tomorrow so I will post some pics ones its up.
Please do! Interested to see the brackets that you mentioned, that install inside of the frame rails. I've never heard about those before. Hope all goes well.
Just finished the install and got back from a test drive. The install was straightforward with the exception of having to trim a tab on 1 of the brackets that sits inside the frame rail. Otherwise no other comments as far as trouble with the install. I did contact the company and asked for some info about how the brackets sit inside the framerail and they sent me a lengthy email explaining which bracket was for what side of the car and some other tips so that was helpful. When I took out the stock LCA's I measured center to center on the holes and set the new LCA's to the same length splitting the distance that each adjustable end was unscrewed.
As far as differences on the first drive, as soon as I started the car up I noticed a difference before the car moved out of the driveway lol. The cam and exhaust previously gave the car a bit of a shake due to the healthy size of the cam, that is all gone now. The car feels much more solid over bumps now as well. I flashed the converter at ~20mph and previously there would be all sorts of drama even with the nittos out back and now an initial quick spin it just hooks and goes. So far I am very please. We'll see if I need to retighten anything after driving it a bit.
On to a couple photos:
EBAY is a store not a BRAND, you can mention the name of the BRAND, just don't link to the ebay pages, you won't violate the forum rules by naming the brand of the parts. Infact, many of the sponsors on this site sell there products on Ebay.
Meh, better safe than sorry. Pretty easy to search on ebay and fine out what brand they are.
I figured I saved at least 100 bucks compared to other brands and another 50-100 by getting bolt-on instead of welded.
Glad you're happy with your purchase OP! Looks better than what I'd imagine from a eBay ripoff suspension company. Although I'd definitely recommend using a vendor with a good reputation of customer service/warranties for future purchases.
LS1Tech Premium Sponsor
Give it up guys... Everyone that's installed this setup has noticed a difference. We get it! You guys have are the only ones that ever made a subframe connector for an F-body. I personally get turned off from a MWC purchase more every time I read your posts in a SFC thread.
It's all about education. Most of the people on this forum are in serious need of the knowledge we offer, and to not be purchasing parts that are not doing the job they are advertised or sold as.
We do not intend to turn people off by our efforts to get this community to understand the differences of the components that are available. I wish more people would chime in about these type of issues, or maybe do a little more research before posting so we don't have to but it just doesn't work that way.
Typically you get what you pay for... and people- PLEASE BUY USA!
personally I don't have any subframe connectors (planned at one point but never did) of any kind because I fear the car will be to stiff, I can feel a noticeably smoother ride when my t-tops are out vs in and I'm going to add that kind of stiffness to the car I don't think I would like the ride quality anymore.
UPDATE- DO NOT BUY THE LOWER CONTROL ARMS. After a wopping 100 miles they started making quite a bit of noise when driving that I can recreate by hitting the center of the lower control arm with my hand when the car is parked. It seems like theres too much play between the ends and the center threaded rod and so the halves start moving against each other. I reached out to the vendor and told them how few miles the setup had on it and the problems and they basically blew me off and said they wouldn't do anything to help me. I still have no issues with the SFC's, but I am not happy with their LCA's.
