Lowering and ground clearance
Oh and someone recommended getting the car aligned with a 1" raise, cause doing so angles the wheel better when drag racing. He said that might give another 1 mph at the track possibly. Said its an old trick a lot of guys do for drag racing. Anyone ever heard of this?
So now you have BMR springs in front with STR.T right?
I think an up to date photo is in order.
Reason why removing a 1/2in spacer caused more than a half inch drop is because of the mounting point of the lower shock on the lower control arm. If the shock was mounted at the end of the control arm (where the ball joint is) I believe then the 1/2in spacer would create exactly a 1/2in raise in the car's ride height. Since in reality, the shock is mounted almost halfway up the lower control arm, a 1/2in spacer would create more than a 1/2in raise/drop. Like the lower ball joint will move 7/8in while the point where the shock mounts to only moves 1/2in, something along those lines...Something to do with fulcrum points or something of that nature... I can't really explain it, I don't feel that smart atm
Just wondering, did you loosen anything else up when you removed the spacers? Sway bar end links or any bushings?
As far as bushing and end links I didn't loosen any of that.
Pics of car?
I'm a little confused how they raised the car 1" though. That is really odd. The most I have seen is around 3/4" of difference with them, but that was an extreme case, light weight car.
Either way, if you ended up not needing them, I will gladly take them back and credit you for them.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Pics of car?
I'm gonna get pics soon for sure. Drove the car home that day after pulling the spacers, and haven't drove it since. My garage has crappier lighting and is small so it's kinda hard to snap nice pics in there lol
Thank you for offering to take them back, I do appreciate that. I think i'll hold on to them though since they may come in handy down the road
Whats your clearance now and how do you feel about the height? I have had a similar mentality as you and was thinking about going less than 1.25".
