Difficulty steering
Old Sep 25, 2016 | 02:26 PM
SS125's Avatar
Default Difficulty steering
I've been working on this project for a long time now. Basically the entire car is new. New motor, trans, rear end, interior and entire front suspension. So I get everything together, running and go to drive the car. Now mind you, this isn't your everyday build. Custom built engine dynoed 1050 hp, Rossler TH400 Transmission, Dana 60 rear end. Took out all power steering, brakes, etc. OMG this thing is a monster but impossible to drive. I've driven old old old cars that are easier to drive than this. It has a BMR tubular K Member, Spohn tubular upper and lower control arms, Pinto rack. Now as far as tires go, it has Hoosier Racing tires (not radials) on the front. I've looked into the electric power steering but to me thats just something else to go wrong. Anybody have any ideas on how to improve the steering on this thing.
Old Sep 26, 2016 | 06:41 AM
wssix99's Avatar
Save the manuals!
It looks like you built this car to race in a straight line. Why do you need to steer? Are you also using it as a street car?
Old Sep 26, 2016 | 07:41 AM
SS125's Avatar
Your right. However, the car d was built for drag week. Gots to street the car a bit there. Also occasional street driving.
Old Sep 26, 2016 | 09:36 AM
AnotherWs6's Avatar
Is the issue that it's hard to turn the wheel or is it doing something else?
Old Sep 26, 2016 | 09:39 AM
SS125's Avatar
Hard to turn understates the problem. There is nothing smooth about turning this steering wheel. It jerks, takes both hands to turn.
Old Sep 26, 2016 | 11:35 AM
wssix99's Avatar
Save the manuals!
Taking the power steering off will make it harder to start. Putting a thick tire contact patch on the rears and make the front contact patches smaller will make your steering way less responsive and will make the car under-steer like crazy - giving you more to fight.
^ Depending on what you did in the rear end, it could make the above impossible to handle. What kind of differential are you using? Do you feel the car wanting to pull to one side or another under acceleration. (ie: are you also fighting torque steer?)
It sounds to me that you are describing driving a tractor. Have you ever done that? It could help here. With such a powerful car and drivetrain, a steering problem may not be in your front end. If your rear wheels don't want to cooperate with you and go around a curve - it won't happen.
Old Sep 26, 2016 | 12:31 PM
1 FMF's Avatar
what amount of caster do you have?
more positive caster will make the front wheels want to stay straight, and increase steering effort. with the power steering removed, you probably need to reduce caster from the oem +4.x°. Guessing to something down around +2°.
And then if you camber & toe is off as well that won't help either.
Old Sep 26, 2016 | 03:38 PM
SS125's Avatar
Your right, it is like driving a tractor and yes I've done that. I don't have a spool in this rear end. I've had one of those and yes, that is not a lot of fun. As far as what has been done to the rear end, It's been changed from a 12 bolt to the Dana 60. Has BMR LCA's, Spohn Torque Arm and Hoosier DOT 10.5" tires in the rear, and a Wolfe Racecraft single sway bar. I took the car out yesterday and tested it a bit and it didn't really pull to one side or the other. Finally, the tires in the front and tires in the back are bias ply tires on 15" wheels. Would it help a bit if they were radials (i.e. drag radials on the back and a skinny radial on the front?
Old Sep 26, 2016 | 03:45 PM
SS125's Avatar
You may have just hit a good point here. WIth all of the changing of the upper and lower control arms, it looks like I've got a lot of negative camber. I'm having an issue trying to get the negative camber out with these control arms. There is only so much adjustment you can do with these things.
Old Sep 26, 2016 | 08:06 PM
wssix99's Avatar
Save the manuals!
What kind of diff did you install in your Dana 60?
Do you still have your old wheels/tires? If so, can put put them on the car? That would be an interesting experiment to use them as a "control" and see how much the new tires are an upsetting component of the equation.
Old Sep 27, 2016 | 09:07 AM
BMR Sales2's Avatar
LS1Tech Premium Sponsor
This is unusual, most customers who switch to a pinto rack report easier and smoother steering, especially over a de-powered stock rack.
When you did the rack conversion, did you use a kit or make your own? I have seen steering shafts with too much working angle on the u-joints causing a bind under turning. This will cause it to be "jerky" and require a lot of steering effort. Running a wider tire in the front does not help with this either, but it still should not be as difficult as you describe. Can you get some pictures of your setup so maybe I can take a look and see if I can identify any issues?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
