quietest torque arm
To get the arm off the tail shaft you would then use a relocation kit that works with the longer arm, this can add a little noise at times but very minimal. Run this with a rubber transmission bushing for best results on noise and vibration. Our part # 2208
If we can help any please ask. Thanks!
The relocation set-up replaces your trans cross member and takes the mounting point of the tail shaft.
You can use aftermarket torque arms or we sell a bushing that will work with a factory torque arm.
This is by far the best set-up if you are looking for ride quality compared to the tunnel mount style.
Craig
Historically, full length arms tend to be the quietest since they attach to an area of the floor that has more bracing and does not seem to resonate road noise the same way a short arm does. We have transmission crossmembers that have a mount provision for the torque arm to get it off of the tailshaft. This allows for use of a stock arm (with a polyurethane bushing) or any aftermarket full length arm.
It looks like you have an LS1 auto car so I would recommend the TCC007.
http://bmrsuspension.com/index.cfm?p...329&superpro=0
As for torque arms, it depends on if your car is lowered, or if you have future plans to. We have adjustable (TA001) and non adjustable (TA002) arms that will work with this crossmember
http://bmrsuspension.com/index.cfm?p...315&superpro=0
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Any added noise will come from two things, one you are not mounting a torque arm to a heavy duty bracket bolted directly under you. Any action the torque arm makes will now travel to you quicker and possibly more noticeable since it is connected more to you now. Two, the arm itself and relocation bracket are built to be heavy duty and not allow flex, factory parts flex and are designed to. We eliminate this.
The most unnoticeable torque arm set up you can do is a full length torque arm bolted in the stock location. When removing the torque arm from the tail shaft is when you could possible increase this. Really it's minimal to none but I guess it depends on you and the car. I would try just the torque arm itself first and go from there.
I hope that helps,
Ryan
