Best performance brake pads for hard braking?
Thanks for responses. I'm using Hawks. I notice braking hard to shave off speed at full throttle brakes hum as I slow to stop. I full K MEMBER upper n lower control arms. I inspected rotors, looks fine. Wondering if car's hp/trq overpowering brakes?
Also get rid of the drilled rotors, they are not helping anything.
They do. The rotors that came on my Z28 from the factory warped, they replaced them and they warped, I replaced them (advance or autozone I don't remember) and they warped. I bought cross drilled off of ebay for if I can remember like $140 shipped for all 4 and I have been trouble Free for I would say 140,000 miles.
Originally intended to help expel gasses from brake pads, however modern day brake pads don't gas out.
There is a ton of theory back and forth for cooling and improved braking, seems all is debunked by now. One thing is clear though, you have a greater chance of cracking the rotors...
The rotors that come on these cars are pretty shitty, mine "warped" as well. The real fix is getting better brake pads. Im still running blank rotors and stopping WAY (high speed and auto-xing) harder than I was when I was on stock pads and have had 0 issues. Read around what the guys who track their cars run, you will see all blank rotors. Modern day race cars are using blank rotors as well...
C6 Lemans racer:
Douchebag On The Tree
Nope.
False.
C6 Lemans racer:
False.
C6 Lemans racer:
Neither cross drilled or slotted do much of anything to benefit modern brake pads. Slotted will help scrap away glazing on pads that get too hot, but if you're using performance pads they most likely won't be getting too hot and you'll just be burning through your expensive pads faster.
Blanks work best because the venting and vanes inside the vent is what cools the rotors, having less surface area or holes on the surface doesn't. In fact, they just give you less rotor mass to deal with the heat.
Quality blanks, quality pads, and keeping your fluid clean and flushed regularly (could even switch to dot 4 fluid) will be more than 99% will ever need. If that's not enough braking, get stickier tires.
Running raybestos blanks, Powerstop evolution carbon fiber ceramic pads on front and ceramic rear pads. All through Rock auto for about the same as part store economy prices.
Nope.
False.
C6 Lemans racer:
False.
C6 Lemans racer:
Drilled rotors are the devil on a road race car. Mine looked 10 times worse than the ones in the picture, one day at the track turned a brand new set into junk, cracked them all the way from the outer edge nearly to the hub, lucky they didn't come apart. I guess that's what happens when you stop repeatedly from over 150 on the back straight and 130 on the front.
