Loud Thud over larger bumps
My WS6 seems to have developed a fairly loud thud from the rear end suspension (or something in the rear area) but only when going over larger potholes or bad patches of road. In September my car was at the local garage and I had the mechanic check all the rear suspension components and check everything was torqued to spec. A slight clunking I had which was from the panhard bar stopped after it was torqued up properly. This new noise seems to be a more physical kind of noise but the car is not bottoming out on the axle bumpers as I've put some grease on the bumpers and non has transferred to the axle at all. Any ideas what it could potentially be?
LS1Tech Premium Sponsor
Is the car lowered or stock height? Look in the transmission tunnel area and see if the torque arm is contacting the tunnel. I have seen that happen on occasion.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Car is stock height on 17inch TT2.
It's not the rear hatch I've already ruled that out. Torque arm and tunnel shows no signs of contact anywhere. It does sound like it's coming from the rear axle area. If I had to describe the sound I'd say it was as if somebody was dropping a 12 crate of beer into the T top storage area of the trunk from a foot above the floor.
I would go over every component. A lot of things can happen in 2 months. A "clunking" can come from a number of components which can all be checked rather easily. You're never going to get a pin point of a clunk from a forum. Chances are it's coming from something either worn out, broke, loose or a clearance issue.
Craig
Craig
Okay sounds good. I'm having the same issue except my shocks are fairly new. I've checked just about everything. I'm getting ready to bring it home for the winter, guess i'll keep looking around...
