Torque arm duties - does it Control Control thrust?
Does the tq arm play any roll at all in laterally locating the rear and? I’ve found both yes and no answers online, both from pretty reputable sources.
I would think the answer would be no, or extremely minimal. Otherwise any tq arm with heims would allow movement? Pictured below is what I’m talking about.
The latter is why the Global West track link is so good. Its a decoupled torque arm that allows its instant center to change with acceleration to deceleration. Flatter stops and able to get on the throttle way earlier in the corner.
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
That's what the PHB and LCA's are for. The LCA's would control thrust of the rear end and the PHB or Watts link does lateral movement. Like 79TA mentioned, having a decoupled torque arm has no ill effect. I would tend to believe a guy (Jason @ UBE) that has a such a good working knowledge on suspension that he designed the one and only (I believe) decoupled torque arm for Fbody's.
Glenn ***
Sales Tech
813.986.9302
If you are able to do this you are using warn out rubber bushings or sub par poly bushings.
