Torque arm clunk
Old Jan 23, 2017 | 02:51 PM
kpayne8980's Avatar
Default Torque arm clunk
Just install a new set of LCA's and Viking rear Coilovers and now when I throttle hard the torque arm clunks. I put a go pro under the car the the axle wraps upward a bit and I hear a clunk. Going to look under car to see if TA is hitting anything but my real question is does the axle wrap up this much normally?
Car is 1/2" lower than it previously sat before the coilover install.
May have to select video to HD to have a clear view.
https://basinsource-my.sharepoint.co...2Df9ce0ac5e632
Old Jan 23, 2017 | 03:13 PM
Hypforlife32's Avatar
is there poly bushings? did you put grease in the zerk fitting?
Old Jan 23, 2017 | 03:32 PM
kpayne8980's Avatar
All greased up. Did you look at the video? Just want to make sure it works.
Old Jan 23, 2017 | 03:52 PM
farmington's Avatar
Did u check the pinion angle with the lower ride height?
Old Jan 23, 2017 | 07:53 PM
kpayne8980's Avatar
yes it is set at -1.5
Old Jan 24, 2017 | 06:55 AM
Corvett z07's Avatar
Went to check out your video and I logged in to my Microsoft account and after that it says "invitation already accepted" or something like that. I guess only one person can view it. If you can upload it to YouTube, that would be gobs better
Old Jan 24, 2017 | 04:36 PM
kpayne8980's Avatar
I'll put it on YouTube tonight
Old Jan 25, 2017 | 12:37 PM
kpayne8980's Avatar
https://www.youtube.com/watch?v=6s3q...ature=youtu.be
New link to video
Old Jan 27, 2017 | 10:42 AM
MidwestChassis2's Avatar
It looked like the torque arm bracket was flexing to me if you watch the video which I am assuming it has a slide link instead of a pivot link. Make sure the bolts on it have not came loose.
Old Feb 8, 2017 | 12:43 PM
kpayne8980's Avatar
It has a pivot link up front. I still can figure out why its making that noise you can hear it in the video.
Old Feb 8, 2017 | 01:44 PM
You put the replacement heim heim LCA on the vehicle and it still has the noise?
Old Feb 10, 2017 | 06:15 AM
kpayne8980's Avatar
Its much less than it was. But it still makes a little noise.
Old Feb 10, 2017 | 08:51 AM
After watching the video I feel it is in the torque arm. After all this have you checked to see if the torque arm is making contact with the floor?
