Stock SS wheels. Best brakes?
Old 06-16-2018 | 12:58 PM
  #241
taman86's Avatar
Has anyone looked into the gen 3 cts j56 brakes non-v model. Those calipers are 150 each, with 13.5 rotors
Old 06-16-2018 | 06:54 PM
  #242
Boosted53F's Avatar
Originally Posted by handyandy
I agree, that looks super close! Boosted, do you have any measurements on how close exactly they are? With the wheels and calipers being aluminum, and all of the joints in the wheel hub/braking system, I'd be worried that under heavy load you get a tiny bit of flex in something and start rubbing. I'm sure it wouldn't be the end of the world, but a little close for comfort for me.
Both the ATS / JL9 setup and the CTS-V setup have calipers with the same pistons/bore sizes, so they apply the same clamping force, but since braking torque=force*radius, those 355mm rotors should provide about 10% more braking torque than the 321mm rotors used in the ATS/JL9 setup. You just have to decide if that 10% is worth the headache of fitment to you and your application.
its a tight fit. I barely took any off the casting on the neck of the caliper... using hand file only. I will take more off next time i swap pads. Im not going to say they are 50% improvement on the base ats calipers, but its a noticeable difference. The taller rotor gives more brake torque which is apparent. I have not had the car on the track yet.
as for fitment, the spoke clearance is the same as the ats calipers. The barrely clearance is maybe 1.5-2mm which is close, but again i barely took any material off. There is plenty of room for wheel weights between the caliper and spoke of wheel, and you may need to move them out further. parts are available and price compared to the base c7/ats is about the same. absolutely the biggest brakes ive seen on stock wheels. I am happy with the upgrade and excited to hit the track by the end of summer.
Cheers
Old 06-16-2018 | 06:55 PM
  #243
Boosted53F's Avatar
i can only assume these are the same calipers discussed and installed throughout this thread.
Old 06-16-2018 | 06:57 PM
  #244
Boosted53F's Avatar
Originally Posted by ilyas
Boosted52F, any concerns with running those on track? Looks like even the wheel weights will be awfully close. I just bought the orange FIFTY calipers on Ebay (ATS style), but am considering re-selling them and going with your same setup...but that looks SO close in the pictures. How big of a spacer did you use? My camaro is strictly a track and autox car.
i am using the same 1/2” hubcentric spacer.
Old 06-16-2018 | 08:06 PM
  #245
taman86's Avatar
Boosted, are you running the 13.5 rotor setup? Also, what calipers did you use? I was looking around and quite a few gm vehicles starting in 2013 use the 13.5 brembo setup including the xts, cts, camaro, and corvette to name a few. But I noticed that the casting numbers were different from the corvette/ Camaro calipers compared to the others running the same 13.5 rotors. Anybody know if that could affect the mounting? Cuz if not you could get the 13.5" calipers A LOT less then the corvette ones.
Old 06-16-2018 | 11:20 PM
  #246
ls2 bait's Avatar
Boosted which calipers are those??
Old 06-17-2018 | 08:42 AM
  #247
Boosted53F's Avatar
yes i am running c7 z51 rotors. 345mm
Old 06-17-2018 | 08:44 AM
  #248
Boosted53F's Avatar
they are xts j55 calipers. Again same part as the c7 z51 calipers, but a fraction of the price.
Old 06-17-2018 | 09:45 AM
  #249
ls2 bait's Avatar
Do you have part numbers?
Old 06-17-2018 | 04:40 PM
  #250
taman86's Avatar
Here are the part numbers I have been able to come up with, everything was sourced from rockauto.
Cts- 1722640- $141.79
1722637- $153.79
xts- A-1 cardone 185481- $167.59
185480- $167.59
c7 jl9- centric part # 14262210- $274.79
14262209- $274.79
c7 j55- 1722621- $364.79
1722624- $364.79
Old 06-17-2018 | 05:09 PM
  #251
5.7stroker's Avatar
1722637- $153.79
4 piston calipers
xts- 1722592- $175.79
1722593- $175.79
2 piston calipers
14262209- $274.79
4 piston calipers
1722624- $364.79
4 piston calipers
One of these is not like the others
Old 06-17-2018 | 11:23 PM
  #252
taman86's Avatar
Edited, thank you for pointing that out. All of those are 13.5" brake calipers
Old 06-20-2018 | 03:46 PM
  #253
5.7stroker's Avatar
The engineer that decided to develop 2 piston calipers for a 13.5" rotor when the other three listed are 4 piston happened to be watching this at the time:
Old 06-21-2018 | 06:45 AM
  #254
biketopia's Avatar
Has any one put hands on that "2 piston" caliper. The pictures show 2 pistons on one side, with it being a fixed caliper, it wouldn't function correctly. It would be constantly trying to deflect the rotor and couldn't compensate for pad wear. Right???
Old 06-22-2018 | 02:12 PM
  #255
handyandy's Avatar
I work in the plant that builds the XTS, and I can assure you wherever it says 2 piston caliper is a typo - they are definitely the same Brembo casting as all of the GM 13.5" rotor calipers. 4 pistons.
The only XTS that gets a 2-piston caliper is the heavy duty / livery / professional option, which are basically the hearses and limos that come factory with 6-bolt hubs. They come with a 2-piston floating caliper that's basically a truck caliper. Just make sure if you're buying XTS calipers you don't get those ones.
Old 06-22-2018 | 03:10 PM
  #256
5.7stroker's Avatar
OK so 1722592 and 1722593 on rockauto for $175.79 ea are 4 piston.
Old 06-23-2018 | 11:33 AM
  #257
taman86's Avatar
Right on, that makes more sense. A fixed 2 piston caliper would literally be the world's most unsafest braking system lol.
Old 07-23-2018 | 01:59 PM
  #258
ilyas's Avatar
Just installed the 6th gen FIFTY Brembo calipers + C7 base rotors. Extremely easy swap. My autox wheels, OEWheels C5Z 17x9.5, fit without spacer with PLENTY of clearance. My track wheels however, stock 02 SS wheels, don't. I tried a 15mm spacer, and it was way too much spacer. I'm thinking a 7mm will be enough. The reason I want as small of a spacer as possible is because a bigger spacer puts more stress on the already weak hubs.
Old 07-23-2018 | 06:38 PM
  #259
Y2KFirehawk's Avatar
Originally Posted by z-camaro
Figured I would post up my go at this upgrade. I shopped around to find a deal on
Used calipers with good pads from ebay - $160
New rotors combo of amazon and ebay - $118
4 custom made adaptors, 15mm from motorsport-tech - $265
Caliper paint G2 - $30
Stickers - $5
Caliper bolts from fastenal - $6
According to my bathroom scale the stock rotors were 19.5 lbs and the new ones were 21 lbs. New calipers were .5 lbs heavier, for a total weight gain of 2 lbs per side. No issues with the stock brake lines.
[Pics removed to reduce bloat]​​​​​​​
Glad to see some Firehawk wheels up in this thread! Nice work! Do you have any more pics of the caliper clearance with the 15mm spacer?
Old 07-30-2018 | 09:18 PM
  #260
z-maro's Avatar
Its hard to get a good picture, but here's what I got.
Quick Reply: Stock SS wheels. Best brakes?
