How to setup strange adjustable shocks when I can't hook
Okay so it usually hooks pretty decent from 2000-2500 rpm, but once I get it on the 2-step building a little boost at about 2700-2800 rpm it is spinning pretty good. Last time I had it at the track with this problem I had the fronts set all the way loose and the backs set about 2-3 clicks off all the way tight...
So do I leave the fronts all the way loose? I'm thinking about taking a few clicks out of the rear to let the weight transfer a little better? Let me know what you guys think..
This is a 1.7 60ft with it hooking
I would loosen the back up to let it plant, and leave the front full loose on rebound until it transfers so hard it comes back and unloads, which it doesnt seem to be doing.
LS1Tech Premium Sponsor
Video made it a little hard to see what the back was doing, but to help out what are the following components and what are they set at:
torque arm, mounting position
lower control arm, mounting position
Are the shocks single adjustable or double?
what tire?
what tire?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Yea fronts soft for weight transfer and then I remember reading you want the rears as stiff as possible as long as you are hooking. If it doesn't hook then I think you are supposed to loosen the rear a bit like 01 mentioned.. I may try to take tire pressure down to about 15-16 psi as well..
