clunk or thud under hard acceleration. is stock trans mount too weak?
hey guys just wondering what your opinions are on my issue i have a typical bolt on ls1. last year i had bad clunking under acceleration so i replaced the trans mount with a new oem one because i didnt want any extra vibration. an i replaced the torque arm mount with prothane.. the clunking went away all is good. now this year i installed a built 4l60e with yanks ss4000 converter. when i floor it as the car is accelerating i can feel a thud or clunk here an there.. do you think the new stock trans mount is too weak? what are your thoughts?
If you broke another Trans mount you could relocate the stock torque arm off the tail shaft with a torque arm relocation bracket. That should help if not take care of breaking rubber Trans mounts.
LS1Tech Premium Sponsor
Yes you can run a poly mount, no matter what motor mounts you have. However, this does normally induce some additional NVH. The biggest problem becomes the stress that is applied tot he tailshaft housing. As all the force is now concentrated on the torque arm mount and where it attaches to the transmission. I have seen this cause failures of the mounts and the tailshaft housing itself. The best fix is to relocate the torque arm off of the trans and onto the crossmember. This can be done using one of our pieces such as this:
https://www.bmrsuspension.com/?page=...329&superpro=0
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
ok being a bolt on car with a 4000 converter and on a budget which do you guys think I should do... just replace trans mount with prothane or get a relocation bracket for 250 an then also replace the trans mount with oem or prothane..
My normal combination of choice is to relocate the arm with a stock trans mount. The rubber mount will help keep driveline nvh transfer to a minimum while not compromising any strength for torque arm mounting
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
OK so what I did was bought the energy mount I did not install the steel plate an I grinded off there preload bumps .. now I have some vibration in my steering wheel an my center console.. I have not gone wot because the roads were wet .. do you think the mount will be more forgiving with some miles put on it?
