kenny brown weld in sfc
I had those in a '96 Z/28 that I had owned for a number of years. Once you loosen the attaching bolts for the rear trailing arms, you slip the "ears" of the SFC behind those bolts, and remove the factory "tunnel brace", and locate the connectors with those mounting holes, you then slide the "arms" connectors up into the subframes, and weld them in place. They pretty much locate themselves.
No.
The body (unibody) is just your frame or framework which the rear axle assembly connects to. And which the front wheel assemblies (upper & lower Ctrl arms, turning knuckle and coil over shock) connect to. These are independent of the body. And the body is supported at 4 points from them- the coil springs. If the suspension is loaded all that's happening is the body is evenly supported from those 4 points, which is really the goal you don't want to introduce twist into the body before welding in an extra support structure. Having the car body up on a lift supported at the 4 lift points would be no different with respect to body twist. What I would not do is a home SFC install and weld in sfc's with one corner jacked up from the ground to get under the car .
Be careful! A couple of the "lift points" that you refer to, might be the points where the SFCs locate. Secondly, on a 2 poster, the unit body tends to "hang", which may not allow it to sit naturally. I'd be more inclined to want to have the suspension at least partially loaded, to have the unit body in it's "natural" state.
