Getting a 4th Gen to Hook Nails!
Old Sep 13, 2017 | 09:03 AM
Phazzy's Avatar
Default Getting a 4th Gen to Hook Nails!
I have a 1999 Camaro SS, with a LQ4 swap! The setup is stock block, milled 799 heads with BTR dual valve springs and a BTR stage 4 cam, a 90mm throttle body, and long tubes. The drivetrain setup is a built th400 with a RMVB with a transbrake, paired to a 12 bolt rear end with 3.73s. The tire/rim setup is a 15×10 racestar, wrapped with 28X11.50-15 Mickey Thompson et street R bias ply. It has a torque arm, subframe connectors, panhard bar, and a adjustable strunt with a lowering spring. What can I do, to make the car hook hard? I want it to hook so hard it will give me whiplash! Looking for the "best bang for your buck" parts.
Old Sep 13, 2017 | 10:05 AM
MidwestChassis's Avatar
LS1Tech Premium Sponsor
I would start with a good double adjustable shocks such as Vikings and then if your rear does not have them I would also consider lca relocation brackets coupled with what you already have would be a good start.
Old Sep 13, 2017 | 11:06 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
^^^ that.
You didn't mention the torque convertor stall rating.
Old Sep 13, 2017 | 01:09 PM
Phazzy's Avatar
Originally Posted by FirstYrLS1Z
^^^ that.
sorry its a Yank 3600 stall
Old Sep 13, 2017 | 01:14 PM
Phazzy's Avatar
I have heard good things about the Vikings. Also everyone seems to be mentioning the LCA's. So ill start with that, and see how she goes.
Old Sep 13, 2017 | 01:23 PM
Bang for the buck you cant beat the Vikings give us a shout when you are ready to order them I didn't notice that you did not mention having the rear Lca's I would also get a good set of them also. https://midwestchassis.com/products/...ble-adjustable
https://midwestchassis.com/products/...ace-adjustable
Old Sep 15, 2017 | 08:53 AM
BMR Sales2's Avatar
Let's start with the basics. What lowering springs and shocks are on the car now? Does your rear end have multiple attachment points for the LCA? If not, a relocation bracket to correct your lower control arm angle would be very beneficial along with a lower control arm. Is the torque arm a tunnel mount style or a full length mounted to the trans crossmember?
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Oct 12, 2017 | 10:02 AM
Phazzy's Avatar
Sam Strano Parts, and no Relocation brakets yet. The torque arm is bolted to a tubular relocation mount. (Beside the transmission)
Old Oct 12, 2017 | 04:17 PM
BMR Sales2's Avatar
If your primary focus is on straight line traction, then relocation brackets are a must for a lowered car. Also, the front springs may be a hold up depending on what brand shocks. If they are Koni's for example, they will limit your ability to launch the car hard. The rears will be fine however. His rates are right in the ideal range for the back of one of these cars.
Also, does your torque arm mount on the crossmember have multiple mounting provisions? What position is it in now?
__________________
Glenn ***
Sales Tech
813.986.9302
Old Jun 17, 2018 | 10:41 PM
Phazzy's Avatar
If I go with Vikings, should I go with coilovers on all 4 corners, or should I go with coils in the front and just a double adjustable shock in the rear with the current spring I have now? Also what doing rates should I look for on a street/strip application?
Old Jun 18, 2018 | 09:16 AM
If a 4-corner coil-over is in your budget there is no disadvantage to them if it is not then the kit with the coil-over front and the smooth body rears will work fine but i would not use the lowering spring if you plan on drag racing the car.
