wolfe racecraft anti roll bar on 02 fbody
Old 09-26-2017, 05:14 PM
bnastystuntz's Avatar
Default wolfe racecraft anti roll bar on 02 fbody
anybody on here have any experience with wolfe racecraft anti roll bar.. chassis shop is bout to install this on my moser fab 9 rear.. 20002 trans am. my issue is with ground clearence.. cant seem to find any pics dipicting how much ground clearence i will have with this bar..... thank you
Old 09-27-2017, 09:49 AM
nobody??
Old 09-27-2017, 12:46 PM
stp001's Avatar
I think that type of sway bar is mounted above the rear end. Different from traditional "factory" sway bars. I don't think you can even see it from the rear when installed.
So.....your picture is probably pretty accurate to represent final application.
Old 09-27-2017, 02:22 PM
i bought the version that mounts to the rear axle tubes not the one that goes between the frame rail. im keeping my stock tank. i have just heard that the style bar i have hangs verry low..
Old 10-02-2017, 06:18 PM
bump anyone
Old 10-03-2017, 08:18 AM
MidwestChassis2's Avatar
I don't know theirs for sure but I couldn't imagine it hanging any lower than the rear end at all. If you look at ours for our fabricated housing it isn't even the lowest point of the rear end.
Old 10-04-2017, 02:03 PM
[QUOTE=MidwestChassis2;19738625]I don't know theirs for sure but I couldn't imagine it hanging any lower than the rear end at all. If you look at ours for our fabricated housing it isn't even the lowest point of the rear end.
from what i understand from lookin at theres based on the crappy pics they have on there site the bar actually
sits basically under the 3rd member
but as u can see this wont work cuz my tq arm has mounting points just like urs does.
from this pic it just longs like the mounting brackets would hang really low if i were to roll it back a lil bit to clear the tq arm mount
this is a lil better pic but not a fab9 and it doesnt depict the car with the wheels on the ground. this also looks like the bar mounts more away from the 3rd member . so this is y im confused
Old 10-05-2017, 09:36 AM
stp001's Avatar
Going on those pictures alone, I would pick a different sway bar. look at the arms and end links in top photo. I doubt that even works!
Old 10-05-2017, 04:15 PM
The rear end is just hanging down, that's why it looks that way.
Old 10-05-2017, 04:17 PM
bnastystuntz we have a bent style that will fit any rear end and will sit in the same location as our straight version. It takes some type of swaybar bracket on the housing to work though. We do offer a weld on style just like the ones we use with our fabricated housings but I have seen people use the muffler stock style clamps before. Not what we recommend but I have seen it done.
Old 12-19-2017, 02:37 PM
just wanted to updage this post for anyone who was curious bout the wolfe racecraft ARB.. chassis guy had to modify it to fit with the moser fab9 rear.. it was rolled back to clear the tq arm. hand to make custom brackets for this setup to work....
Old 01-20-2018, 08:33 AM
allblackedout5's Avatar
Why bother with that beautiful rear end and suspension with those crappy old shocks???? lol jk..
Yellow not my cup of tea but that install looks very nice.
Old 01-22-2018, 11:29 PM
lol there just on there for mock up... will be installing afco 2 way adjustable shock
Old 01-23-2018, 11:01 AM
01ssreda4's Avatar
Yes those style bars hang a little lower then others, but i highly doubt youll have any issues with it.
Old 01-23-2018, 12:00 PM
AnotherWs6's Avatar
That's what I thought. Guy pops for a fabbed 9 inch and is still running decarbons. lol.
Quick Reply: wolfe racecraft anti roll bar on 02 fbody
