Factory Ride Height Spec?
LS1Tech Premium Sponsor
Stock ride height for these cars, as measure from the ground to the center of the wheel openings is typically 27-3/4" - 28"
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Just for reference, with my lowering springs I'm now 26.5" front and 26.75" rear, and even with low hanging ORY its not that bad. I definitely wouldn't want to be lower though. My lowest point is my ORY pipe which has a 3" clearance from the ground
All depends what springs and shocks. Mine has stock springs and decarbon shocks up front and the front is 28 1/2 inches from the ground and the rear has stock springs and Gabriel shocks and it sits 29 inches from the ground. I don't believe theres a set in stone ride height for these cars, as it is apparent they're all a bit different.
Racing alignment shops will all do this. Put a a scale under each wheel. Set the height then cross balance it with the driver in the seat.
http://www.turnology.com/features/co...han-you-think/
