Shocks and Wheel Hop
Hey Guys,
Working on trying to get rid of wheel hop and am looking hard at shocks now. The car is a 99 Z28 M6 sitting on BMR springs with Koni yellows up front and stock shocks in the rear with an 8.8", welded LCA relocation brackets, UMI adjustable control arms, UMI panhard and relocation kit. Car is street driven and has yet to see a track but I'd like to get it there this summer.
A torque arm relocation is in the plans, but I'm thinking changing out those shocks will have the highest chance of success. Are the Koni yellows worth the extra money? If I could get away with a pair of Str.t I could nearly buy the TA relocation with the money saved. Having said that I'm pretty tired of buying things twice because I was looking to save a few bucks. Any recommendations?
Thanks
Thanks
Aftermarket torque arm is currently number 3 on my list. I can't do all this at once so I figured relocating the stock one would be a good start.
Yeah, I've got the brackets and the control arms are slightly lower on the diff side. As far as I can see, shocks or torque arm is the next step.
LS1TECH Sponsor
I'll make it simple.
Shocks control mass. compression damping controls unsprung mass. Rebound damping controls sprung mass and the springs themselves. Stock shocks are terrible at all of this to start with, beyond that you put on stiffer springs, which are also shorter, a heavier rear axle, and I assume a larger than stock wheel/tire setup, but maybe not being my crystal ball is on the fritz.
You missed the most important things, which are good shocks. And Sports are better, period. STR.T's are better than stock because they aren't stock and have 15+ years of age and wear on them, but Sports also have more compression damping to help with the gain in unsprung weight.
In short, you have parts that don't help the problem and are considering more parts that are not a great solve for the problem in the wrong shocks for the job.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Well that worked out well as I just got an email saying my STR.T's are backorder, gonna try to find some Sports. Thanks for the input.
LS1TECH Sponsor
Or not.
Too bad I had some STR.T's if that's what you wanted. But I"m running low on them anyway. But have lots of Sports of both the on and off car adjustable rear type.
__________________
I was trying to find them in Canada to no avail as border fees can be pretty crazy, so I went ahead and ordered the Sports from Stranoparts. Thanks again, I'll report back when I get them in.
LS1TECH Sponsor
Excellent. Glad to hear it, and maybe the next guy will understand shocks do a lot more than most folks think. Thanks for the feedback!
__________________
